LTC6244 ELECTRICAL CHARACTERISTICSNote 1: Stresses beyond those listed under Absolute Maximum Ratings Note 6: This parameter is not 100% tested. may cause permanent damage to the device. Exposure to any Absolute Note 7: This specifi cation is limited by high speed automated test Maximum Rating condition for extended periods may affect device capability. See Typical Characteristics curves for actual typical reliability and lifetime. performance. Note 2: A heat sink may be required to keep the junction temperature Note 8: Current noise is calculated from the formula: in = (2qIB)1/2 below the absolute maximum rating when the output is shorted where q = 1.6 × 10–19 coulomb. The noise of source resistors up to indefi nitely. 50GΩ dominates the contribution of current noise. See also Typical Note 3: The LTC6244C/LTC6244HVC are guaranteed to meet specifi ed Characteristics curve Noise Current vs Frequency. performance from 0°C to 70°C. They are designed, characterized and Note 9: Output voltage swings are measured between the output and expected to meet specifi ed performance from –40°C to 85°C, but are not power supply rails. tested or QA sampled at these temperatures. The LTC6244I/LTC6244HVI, Note 10: Minimum supply voltage is guaranteed by the power supply are guaranteed to meet specifi ed performance from –40°C to 85°C. The rejection ratio test. LTC6244H is guaranteed to meet specifi ed performance from –40°C to Note 11: Slew rate is measured in a gain of –2 with R 125°C. F = 1k and RG = 500Ω. VIN is ±1V and VOUT slew rate is measured between –1V and +1V. Note 4: ESD (Electrostatic Discharge) sensitive device. ESD protection On the LTC6244HV/LTC6245HV, VIN is ±2V and VOUT slew rate is measured devices are used extensively internal to the LTC6244; however, high between –2V and +2V. electrostatic discharge can damage or degrade the device. Use proper ESD Note 12: Full-power bandwidth is calculated from the slew rate: handling precautions. FPBW = SR/2πVP. Note 5: Matching parameters are the difference between the two amplifi ers of the LTC6244. CMRR and PSRR match are defi ned as follows: CMRR and PSRR are measured in μV/V on the amplifi ers. The difference is calculated between the sides in μV/V. The result is converted to dB. 6244fb 9
