Datasheet LT6013, LT6014 (Analog Devices) - 2
DescriptionSingle/Dual 145µA, 9.5nV/√Hz, AV ≥5, Rail-to-Rail Output Precision Op Amps
Pages / Page16 / 2 — ABSOLUTE AXI U RATI GS (Note 1). PACKAGE/ORDER I FOR ATIO
File Format / SizePDF / 346 Kb
ABSOLUTE AXI U RATI GS (Note 1) PACKAGE/ORDER I FOR ATIO
LT6013/LT6014
W W W U ABSOLUTE AXI U RATI GS (Note 1)
Total Supply Voltage (V+ to V–) .. 40V Maximum Junction Temperature Differential Input Voltage (Note 2) .. 10V DD Package ... 125°C Input Voltage .. V+ to V– S8 Package .. 150°C Input Current (Note 2) ... ±10mA Storage Temperature Range Output Short-Circuit Duration (Note 3) ... Indefinite DD Package ... – 65°C to 125°C Operating Temperature Range (Note 4) .. – 40°C to 85°C S8 Package .. – 65°C to 150°C Specified Temperature Range (Note 5) ... – 40°C to 85°C Lead Temperature (Soldering, 10 sec).. 300°C
U W U PACKAGE/ORDER I FOR ATIO
ORDER PART ORDER PART NUMBER NUMBER TOP VIEW TOP VIEW LT6013CDD LT6013CS8 *DNC 1 8 *DNC *DNC 1 8 *DNC LT6013IDD LT6013IS8 –IN 2 – 7 V+ –IN 2 LT6013ACDD – 7 V+ LT6013ACS8 +IN 3 + 6 OUT +IN 3 + 6 OUT LT6013AIDD LT6013AIS8 V– 4 5 NC V– 4 5 NC DD PART MARKING* S8 PART MARKING DD PACKAGE S8 PACKAGE 8-LEAD (3mm × 3mm) PLASTIC DFN 8-LEAD PLASTIC SO LBHC 6013 TJMAX = 125°C, θJA = 160°C/W TJMAX = 150°C, θJA = 190°C/W UNDERSIDE METAL CONNECTED TO V– 6013I (PCB CONNECTION OPTIONAL) 6013A 6013AI *Do Not Connect *Do Not Connect ORDER PART ORDER PART NUMBER NUMBER TOP VIEW LT6014CDD TOP VIEW LT6014CS8 OUT A 1 8 V+ LT6014IDD OUT A 1 8 V+ LT6014IS8 –IN A 2 7 OUT B A LT6014ACDD –IN A 2 7 OUT B LT6014ACS8 +IN A 3 6 –IN B A B +IN A –IN B V– 3 6 4 5 +IN B LT6014AIDD LT6014AIS8 B V– 4 5 +IN B DD PART MARKING* S8 PART MARKING DD PACKAGE S8 PACKAGE 8-LEAD (3mm × 3mm) PLASTIC DFN 8-LEAD PLASTIC SO 6014 LBCB TJMAX = 125°C, θJA = 160°C/W TJMAX = 150°C, θJA = 190°C/W UNDERSIDE METAL CONNECTED TO V– 6014I (PCB CONNECTION OPTIONAL) 6014A 6014AI *Temperature and electrical grades are identified by a label on the shipping container. Consult LTC Marketing for parts specified with wider operating temperature ranges. 60134fb 2
