Datasheet LT6013, LT6014 (Analog Devices) - 7
DescriptionSingle/Dual 145µA, 9.5nV/√Hz, AV ≥5, Rail-to-Rail Output Precision Op Amps
Pages / Page16 / 7 — ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply …
File Format / SizePDF / 346 Kb
ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply over the full operating
LT6013/LT6014
C. VS =
15V, VCM = 0V, RL to 0V, unless otherwise specified. (Note 5) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOUT Maximum Output Swing No Load, 50mV Overdrive 45 80 mV (Positive, Referred to V+) ● 100 mV ISOURCE = 1mA, 50mV Overdrive 140 195 mV ● 240 mV Maximum Output Swing No Load, 50mV Overdrive 45 80 mV (Negative, Referred to V–) ● 100 mV ISINK = 1mA, 50mV Overdrive 150 250 mV ● 300 mV ISC Output Short-Circuit Current VOUT = 0V, 1V Overdrive (Source) 8 15 mA (Note 3) ● 5 mA VOUT = 0V, –1V Overdrive (Sink) 8 20 mA ● 5 mA SR Slew Rate AV = –10, RF = 50k, RG = 5k 0.15 0.2 V/µs TA = 0°C to 70°C ● 0.12 V/µs TA = –40°C to 85°C ● 0.1 V/µs GBW Gain Bandwidth Product f = 10kHz 1.1 1.6 MHz ● 1 MHz ts Settling Time AV = –4, 0.01%, VOUT = 0V to 10V 40 µs tr, tf Rise Time, Fall Time AV = 5, 10% to 90%, 0.1V Step 0.9 µs ∆VOS Offset Voltage Match (Note 7) LT6014AS8 50 270 µV TA = 0°C to 70°C ● 320 µV TA = –40°C to 85°C ● 370 µV LT6014ADD 50 320 µV TA = 0°C to 70°C ● 420 µV TA = –40°C to 85°C ● 450 µV LT6014S8 70 300 µV TA = 0°C to 70°C ● 350 µV TA = –40°C to 85°C ● 400 µV LT6014DD 80 400 µV TA = 0°C to 70°C ● 500 µV TA = –40°C to 85°C ● 550 µV ∆IB Input Bias Current Match (Note 7) LT6014AS8, LT6014ADD 200 800 pA TA = 0°C to 70°C ● 1200 pA TA = –40°C to 85°C ● 1400 pA LT6014S8, LT6014DD 300 1600 pA TA = 0°C to 70°C ● 2000 pA TA = –40°C to 85°C ● 2400 pA ∆CMRR Common Mode Rejection Ratio LT6014 ● 109 135 dB Match (Note 7) ∆PSRR Power Supply Rejection Ratio LT6014 ● 106 135 dB Match (Note 7) IS Supply Current per Amplifier 200 250 µA TA = 0°C to 70°C ● 290 µA TA = –40°C to 85°C ● 310 µA 60134fb 7
