Datasheet LT6013, LT6014 (Analog Devices) - 9
DescriptionSingle/Dual 145µA, 9.5nV/√Hz, AV ≥5, Rail-to-Rail Output Precision Op Amps
Pages / Page16 / 9 — TYPICAL PERFOR A CE CHARACTERISTICS. Total Input Noise. vs Source …
File Format / SizePDF / 346 Kb
TYPICAL PERFOR A CE CHARACTERISTICS. Total Input Noise. vs Source Resistance. 0.1Hz to 10Hz Voltage Noise. n, in vs Frequency
TYPICAL PERFOR A CE CHARACTERISTICS Total Input Noise vs Source Resistance 0.1Hz to 10Hz Voltage Noise n, in vs Frequency
LT6013/LT6014
W U TYPICAL PERFOR A CE CHARACTERISTICS Total Input Noise e vs Source Resistance 0.1Hz to 10Hz Voltage Noise n, in vs Frequency
1000 10 INPUT CURRENT NOISE DENSITY (fA/ VS = 5V, 0V VS = 5V, 0V Hz) CURRENT NOISE TA = 25°C TA = 25°C √ UNBALANCED f = 1kHz SOURCE RESISTORS 1 Hz) UNBALANCED V/DIV) √ µ SOURCE RESISTORS 1/f CORNER = 40Hz V/ µ 0.1 10 100 TOTAL NOISE 1/f CORNER = 2Hz VOLTAGE NOISE 0.01 RESISTOR NOISE ONLY TOTAL INPUT NOISE ( 0.001 √Hz) INPUT VOLTAGE NOISE (0.1 VS = 5V, 0V INPUT VOLTAGE NOISE DENSITY (nV/ TA = 25°C 1 0.0001 1 10 100 1000 100 1k 10k 100k 1M 10M 100M 0 1 2 3 4 5 6 7 8 9 10 FREQUENCY (Hz) SOURCE RESISTANCE (Ω) TIME (SEC) 60134 G07 60134 G08 60134 G09
0.01Hz to 1Hz Voltage Noise 0.1Hz to 10Hz Current Noise 0.01Hz to 1Hz Current Noise
VS = 5V, 0V V V S = 5V, 0V S = 5V, 0V TA = 25°C T T A = 25°C A = 25°C BALANCED SOURCE RESISTANCE BALANCED SOURCE RESISTANCE V/DIV) µ INPUT VOLTAGE NOISE (0.1 INPUT CURRENT NOISE (2pA/DIV) INPUT CURRENT NOISE (2pA/DIV) 0 10 20 30 40 50 60 70 80 90 100 0 1 2 3 4 5 6 7 8 9 10 0 10 20 30 40 50 60 70 80 90 100 TIME (SEC) TIME (SEC) TIME (SEC) 60134 G10 60134 G31 60134 G32
Output Voltage Swing Output Saturation Voltage Output Saturation Voltage vs Temperature vs Load Current (Output High) vs Load Current (Output Low)
V+ 1 1 V V S = 5V, 0V S = 5V, 0V VS = 5V, 0V –20 NO LOAD –40 OUTPUT HIGH TA = 85°C TA = 85°C –60 TA = 25°C TA = 25°C 0.1 0.1 T 60 A = –40°C OUTPUT LOW TA = –40°C 40 OUTPUT VOLTAGE SWING (mV) 20 OUTPUT HIGH SATURATION VOLTAGE (V) OUTPUT LOW SATURATION VOLTAGE (V) V– 0.01 0.01 – 50 – 25 0 25 50 75 100 125 0.01 0.1 1 10 0.01 0.1 1 10 TEMPERATURE (°C) LOAD CURRENT (mA) LOAD CURRENT (mA) 60134 G12 60134 G11 60134 G13 60134fb 9
