Datasheet LT1457 (Analog Devices) - 4
DescriptionDual, Precision JFET Input Op Amp
Pages / Page8 / 4 — TYPICAL PERFORMANCE CHARACTERISTICS. Input Bias and Offset Current vs. …
File Format / SizePDF / 226 Kb
TYPICAL PERFORMANCE CHARACTERISTICS. Input Bias and Offset Current vs. Input Bias Current Over. Temperature
TYPICAL PERFORMANCE CHARACTERISTICS Input Bias and Offset Current vs Input Bias Current Over Temperature
LT1457
W U TYPICAL PERFORMANCE CHARACTERISTICS Input Bias and Offset Current vs Input Bias Current Over Temperature the Common-Mode Range Warm-Up Drift
1000 160 150 VS = ±15V V V S = ±15V S = ±15V 140 VCM = 0V TA = 25°C 300 WARMED UP µV) 120 120 100 100 S8 PACKAGE TA = 70°C 90 80 BIAS CURRENT 60 30 60 40 N8 PACKAGE INPUT BIAS CURRENT (pA) 10 20 30 OFFSET CURRENT CHANGE IN OFFSET VOLTAGE ( 0 INPUT BIAS AND OFFSET CURRENT (pA) TA = 25°C 3 –20 0 0 25 50 75 100 –15 –10 –5 0 5 10 15 0 1 2 3 4 5 AMBIENT TEMPERATURE (°C) COMMON-MODE INPUT VOLTAGE (V) TIME AFTER POWER ON (MINUTES) LT1457 • TPC01 LT1457 • TPC02 LT1457 • TPC03
Input Offset Voltage Distribution Long Term Drift of N8 Package Voltage Gain vs Temperature Representative Units
24 1000 50 VS = ±15V 900 DUALS VS = ±15V VS = ±15V 40 21 TA = 25°C (1800 OP AMPS) R V L = 2k O = ±10V TA = 25°C TESTED FROM 3 30 µV) 18 RUNS 300 20 RL = 1k 15 10 12 100 0 –10 9 PERCENT OF UNITS –20 VOLTAGE GAIN (V/mV) 6 30 –30 OFFSET VOLTAGE CHANGE ( 3 –40 0 10 –50 –0.8 –0.6 –0.4 –0.2 0 0.2 0.4 0.6 0.8 –50 –25 0 25 50 75 100 0 1 2 3 4 5 INPUT OFFSET VOLTAGE (mV) TEMPERATURE (°C) TIME (MONTHS) LT1457 • TPC04 LT1457 • TPC05 LT1457 • TPC06
Voltage Noise vs Frequency 0.1Hz to 10Hz Noise Channel Separation vs Frequency
100 160 VS = ±15V VS = ±15V √Hz) 70 TA = 25°C TA = 25°C 140 LIMITED BY 50 µV/DIV) THERMAL RS = 10Ω 120 INTERACTION AT DC = 132dB 30 LIMITED BY PIN TO 100 PIN CAPACITANCE 20 V NOISE VOLTAGE (1 S = ±15V CHANNEL SEPARATION (dB) 80 TA = 25°C VIN = 20VP-P TO 5kHz RS = 1k RMS VOLTAGE NOISE DENSITY (nV/ 1/f CORNER = 28Hz RL = 2k 10 60 3 10 30 100 300 1k 3k 10k 0 2 4 6 8 10 1 10 100 1k 10k 100k 1M FREQUENCY (Hz) TIME (SECONDS) FREQUENCY (Hz) LT1457 • TPC07 LT1457 • TPC08 LT1457 • TPC09 4
