Datasheet RH1056A (Analog Devices) - 4
Description | Precision, High Speed, JFET Input Operational Amplifier |
Pages / Page | 4 / 4 — TYPICAL PERFORMANCE CHARACTERISTICS. Input Offset Voltage. Open-Loop … |
Revision | D |
File Format / Size | PDF / 190 Kb |
TYPICAL PERFORMANCE CHARACTERISTICS. Input Offset Voltage. Open-Loop Gain. Input Bias Current. Common Mode Rejection Ratio
RH1056A
TYPICAL PERFORMANCE CHARACTERISTICS Input Offset Voltage Open-Loop Gain
0.6 350 V V S = ±15V S = ±15V VO = ±10V 0.4 VCM= 0V 300 250 RL = 2k 0.2 RL = 1k 200 0 150 –0.2 100 OPEN-LOOP GAIN (V/mV) INPUT OFFSET VOLTAGE (mV) –0.4 50 –0.6 0 1 10 100 1000 1 10 100 1000 TOTAL DOSE KRADs (Si) TOTAL DOSE KRADs (Si) 1056A G01 1056A G02
Input Bias Current Common Mode Rejection Ratio
3.0 130 VS = ±15V VS = ±15V 2.5 VCM = 0V 120 VCM = ±11V 2.0 110 1.5 100 1.0 90 0.5 80 INPUT BIAS CURRENT (nA) 0 70 COMMON MODE REJECTION RATIO (dB) –0.5 60 1 10 100 1000 1 10 100 1000 TOTAL DOSE KRADs (Si) TOTAL DOSE KRADs (Si) 1056A G03 1056A G04
Input Offset Current Power Supply Rejection Ratio
0.4 130 VS = ±15V VS = ±10V TO ±18V 0.3 VCM = 0V 120 0.2 110 0.1 100 0 90 –0.1 80 INPUT OFFSET CURRENT (nA) –0.2 70 POWER SUPPLY REJECTION RATIO (dB) –0.3 60 1 10 100 1000 1 10 100 1000 TOTAL DOSE KRADs (Si) TOTAL DOSE KRADs (Si) 1056A G05 1056A G06 ID No. 66-10-0160 Rev D 4 D17022-0-6/18(D) www.analog.com For more information www.analog.com ANALOG DEVICES, INC. 1989-2018 Document Outline Package Information Burn-In Circuit Table 2: Electrical Test Requirements Total Dose Bias Circuit Revision History
