Datasheet LT1055, LT1056 (Analog Devices) - 8
DescriptionPrecision, High Speed, JFET Input Operational Amplifiers
Pages / Page20 / 8 — TYPICAL PERFORMANCE CHARACTERISTICS. Gain vs Frequency. Gain, Phase Shift …
File Format / SizePDF / 329 Kb
TYPICAL PERFORMANCE CHARACTERISTICS. Gain vs Frequency. Gain, Phase Shift vs Frequency. Voltage Gain vs Temperature
TYPICAL PERFORMANCE CHARACTERISTICS Gain vs Frequency Gain, Phase Shift vs Frequency Voltage Gain vs Temperature
LT1055/LT1056
140 100 1000 VS = ±15V VS = ±15V 120 TA = 25°C V 20 R O = ±10V PHASE L = 2k PHASE SHIFT (DEGREES) 100 120 300 LT1055 LT1056 R 80 L = 1k 10 60 GAIN 100 GAIN (dB) LT1055 LT1056 GAIN (dB) 140 40 LT1055 LT1056 0 20 VOLTAGE GAIN (V/mV) 30 0 160 VS = ±15V TA = 25°C –20 –10 10 1 10 100 1k 10k 100k 1M 10M 100M 1 2 4 6 8 10 –75 –25 25 75 125 FREQUENCY (Hz) FREQUENCY (MHz) TEMPERATURE (°C) LT1055/56 G16 LT1055/56 G17 LT1055/56 G18
Common Mode Range vs LT1055 Settling Time LT1056 Settling Time Temperature
10 10 15 2mV 14 10mV 0.5mV 10mV 2mV 0.5mV 13 5 5 12 11 5mV 1mV 5mV 1mV V 0 0 S = ±15V ±10 5mV 2mV 5mV TA = 25°C –11 –12 –5 –5 BATTERY VOLTAGE (V) 10mV 1mV 0.5mV 10mV 2mV 1mV 0.5mV –13 OUTPUT VOLTAGE SWING FROM 0V (V) VS = ±15V –14 T OUTPUT VOLTAGE SWING FROM 0V (V) A = 25°C VS = ±15V –10 –10 –15 0 1 2 3 0 1 2 3 –50 0 50 100 SETTLING TIME (µS) SETTLING TIME (µS) TEMPERATURE (°C) LT1055/56 G19 LT1055/56 G20 LT1055/56 G21
Common Mode and Power Supply Common Mode Rejection Ratio vs Power Supply Rejection Ratio vs Rejections vs Temperature Frequency Frequency
120 120 140 VS = ±10V TO ±17V FOR PSRR VS = ±15V TA = 25°C VS = ±15V, VCM = ±10.5V FOR CMRR TA = 25°C 100 120 100 110 80 POSITIVE PSRR 80 SUPPLY 60 NEGATIVE 60 CMRR CMRR (dB) SUPPLY CMRR, PSRR (dB) 100 40 40 20 20 POWER SUPPLY REJECTION RATIO (dB) 90 0 0 –25 25 75 125 10 100 1k 10k 100k 1M 10M 10 100 1k 10k 100k 1M 10M TEMPERATURE (°C) FREQUENCY (Hz) FREQUENCY (Hz) LT1055/56 G22 LT1055/56 G23 LT1055/56 G24 10556fd 8 For more information www.linear.com/LT1055 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Applications Information Typical Applications Simplified schematic Package Description Revision History Typical Application Related Parts
