Datasheet LT1012A, LT1012 (Analog Devices) - 5
DescriptionPicoamp Input Current, Microvolt Offset, Low Noise Op Amp
Pages / Page20 / 5 — ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply …
File Format / SizePDF / 348 Kb
ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply over the full operating. temperature range of –55. 125
ELECTRICAL CHARACTERISTICS The denotes the specifications which apply over the full operating temperature range of –55 125
LT1012A/LT1012
C
TA
125
C for LT1012AM and LT1012M, and –40
C
TA
85
C for LT1012AI and LT1012I. VS =
15V, VCM = 0V, unless otherwise noted. LT1012AM/AI LT1012M/I SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
VOS Input Offset Voltage ● 30 60 30 180 µV (Note 3) ● 40 180 40 250 µV Average Temperature Coefficient of ● 0.2 0.6 0.2 1.5 µV/°C Input Offset Voltage IOS Input Offset Current ● 30 250 30 250 pA (Note 3) ● 70 350 70 350 pA Average Temperature Coefficient of ● 0.3 2.5 0.3 2.5 pA/°C Input Offset Current IB Input Bias Current ● ±80 ±600 ±80 ±600 pA (Note 3) ● ±150 ±800 ±150 ±800 pA Average Temperature Coefficient of ● 0.6 6.0 0.6 6.0 pA/°C Input Bias Current AVOL Large-Signal Voltage Gain VOUT = ±12V, RL ≥ 10kΩ ● 200 1000 150 1000 V/mV VOUT = ±10V, RL ≥ 2kΩ ● 200 600 100 600 V/mV CMRR Common Mode Rejection Ratio VCM = ±13.5V ● 110 128 108 128 dB PSRR Power Supply Rejection Ratio VS = ±1.5V to ± 20V ● 110 126 108 126 dB Input Voltage Range ● ±13.5 ±13.5 V VOUT Output Voltage Swing RL = 10kΩ ● ±13 ±14 ±13 ±14 V IS Supply Current ● 400 650 400 800 µA sn1012 1012afbs 5
