Datasheet LT1008 (Analog Devices) - 2
Description | Picoamp Input Current, Microvolt Offset, Low Noise Op Amp |
Pages / Page | 16 / 2 — ABSOLUTE AXI U RATI GS (Note 1). (OBSOLETE) ... PACKAGE/ORDER I FOR ATIO. … |
File Format / Size | PDF / 283 Kb |
ABSOLUTE AXI U RATI GS (Note 1). (OBSOLETE) ... PACKAGE/ORDER I FOR ATIO. Order Options. OBSOLETE PACKAGES
LT1008
W W W U ABSOLUTE AXI U RATI GS (Note 1)
Supply Voltage .. ±20V Operating Temperature Range Differential Input Current (Note 2) ... ±10mA LT1008M
(OBSOLETE) ...
– 55°C to 125°C Input Voltage .. ±20V LT1008C ... 0°C to 70°C Output Short-Circuit Duration ... Indefinite LT1008I ... – 40°C to 85°C Storage Temperature Range ... – 65°C to 150°C Lead Temperature (Soldering, 10 sec).. 300°C
U W U PACKAGE/ORDER I FOR ATIO
TOP VIEW TOP VIEW COMP2 TOP VIEW 8 COMP1 1 8 COMP2 COMP1 1 7 V+ COMP1 1 8 COMP2 –IN 2 7 V+ – –IN 2 7 V+ –IN 2 6 OUT +IN 3 6 OUT + V– +IN OUT 4 3 6 5 NC +IN 3 5 NC V– 4 5 NC 4 N8 PACKAGE V– (CASE) 8-LEAD PDIP S8 PACKAGE H PACKAGE TJMAX = 150°C, θJA = 130°C/W 8-LEAD PLASTIC SO 8-LEAD TO-5 METAL CAN TJMAX = 150°C, θJA = 190°C/W T J8 PACKAGE 8-LEAD CERDIP JMAX = 150°C, θJA = 150°C/W, θJC = 45°C/W TJMAX = 150°C, θJA = 100°C/W ORDER PART ORDER PART ORDER PART ORDER PART S8 PART NUMBER NUMBER NUMBER NUMBER MARKING LT1008MH LT1008MJ8 LT1008CN8 LT1008S8 1008 LT1008CH LT1008CJ8 LT1008IN8
Order Options
Tape and Reel: Add #TR
OBSOLETE PACKAGES
Lead Free: Add #PBF Lead Free Tape and Reel: Add #TRPBF Consider N8 or S8 Package for Alternate Source Lead Free Part Marking: http://www.linear.com/leadfree/ Consult LTC Marketing for parts specified with wider operating temperature ranges.
ELECTRICAL CHARACTERISTICS VS =
15V, VCM = 0V, TA = 25
C, unless otherwise noted. LT1008M/I LT1008C SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
VOS Input Offset Voltage 30 120 30 120 μV (Note 3) 40 180 40 180 μV Long-Term Input Offset Voltage Stability 0.3 0.3 μV/Month IOS Input Offset Current 30 100 30 100 pA (Note 3) 40 150 40 150 pA IB Input Bias Current ±30 ±100 ±30 ±100 pA (Note 3) ±40 ±150 ±40 ±150 pA en Input Noise Voltage 0.1Hz to 10Hz 0.5 0.5 μVP-P Input Noise Voltage Density fO = 10Hz (Note 4) 17 30 17 30 nV√Hz fO = 1000Hz (Note 5) 14 22 14 22 nV/√Hz in Input Noise Current Density fO = 10Hz 20 20 fA/√Hz AVOL Large-Signal Voltage Gain VOUT = ±12V, RL ≥ 10k 200 2000 200 2000 V/mV VOUT = ±10V, RL ≥ 2k 120 600 120 600 V/mV 1008fb 2
