Datasheet LT3668 (Analog Devices) - 3
Description40V 400mA Step-Down Switching Regulator with Dual Fault Protected Tracking LDOs
Pages / Page28 / 3 — ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply …
File Format / SizePDF / 386 Kb
ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply over the full operating
LT3668
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. VIN1 = 12V unless otherwise noted. (Note 4) PARAMETER CONDITIONS MIN TYP MAX UNITS
VIN1 Undervoltage Lockout (Note 6) VIN2 = 0V, VIN3/BD = 0V l 4 4.3 V VIN1 Overvoltage Lockout l 40 42 44 V VIN2 Undervoltage Lockout (Note 6) VIN1 = 3.5V, VIN3/BD = 0V l 4 4.3 V Quiescent Current from IN1 VEN = 0.3V 0.01 1 µA VEN = 12V, VIN2 = 0V, Not Switching l 13 30 µA Quiescent Current from IN2 VEN = 0.3V 0.01 1 µA VEN = 12V, VIN1 = 0V, VIN2 = 5V l 38 80 µA Quiescent Current from IN1 + IN2 VEN = 0.3V, VIN2 = 5V 0.01 1 µA VEN = 12V, VIN2 = 5V, Not Switching l 40 90 µA Quiescent Current from IN3/BD VEN = 0.3V, VIN3/BD = 5V 0.01 1 µA VEN = 12V, VIN3/BD = 5V l 25 60 µA EN Pin Current VEN = 12V 0.6 2 µA EN Input Threshold 0.3 1.1 V
Power Good Pin PG
Leakage Current VPG = 5V 0.1 1 µA Output Voltage Low IPG = 40µA l 0.2 0.3 V Threshold as % of VFB1 Pin Voltage Falling 88 90 92 % Pin Voltage Rising 108 110 112 % PG Threshold Hysteresis Measured at FB1 Pin 30 mV
Switching Regulator
Switching Frequency RT = 37.4k l 1.8 2.0 2.1 MHz RT = 102k l 0.8 0.94 1.1 MHz RT = 487k l 220 243 300 kHz Minimum Switch Off-Time l 120 190 ns Switch Current Limit (Note 7) 5% Duty Cycle, VIN = 5V, VFB1 = 0V l 600 750 950 mA 90% Duty Cycle, VIN = 5V, VFB1 = 0V l 450 550 800 mA Switch VCESAT ISW = 200mA 300 mV DA Pin Current to Stop Switching l 420 500 650 mA Switch Leakage Current VSW = 0V 0.05 2 µA Boost Schottky Diode Forward Voltage IBOOSTDIODE = 50mA, VIN = NC, VBOOST = 0V 900 mV Boost Schottky Diode Reverse Leakage VREVERSE = 12V, VIN = NC 0.04 4 µA Minimum Boost Voltage (Note 8) l 1.7 2.5 V BOOST Pin Current ISW = 200mA, VBOOST = 15V 10 16 mA Feedback Voltage (FB1) 1.188 1.2 1.212 V l 1.176 1.2 1.224 mV FB1 Pin Bias Current Pin Voltage = 1.2V l 0.1 20 nA Reference Voltage Line Regulation 4.2V < VIN1 < 40V 0.001 0.005 %/V
Each LDO Regulator
Minimum Input Voltage ILOAD = 200mA l 1.6 2.2 V Output Voltage Range l 1.1 10 V Tracking Error VOUT2/3-VADJ2/3 1.1V ≤ VADJ2/3 ≤ 5V, ILOAD = 1mA –40°C to 125°C l –6 6 mV 5V < VADJ2/3 ≤ 10V, ILOAD = 1mA –40°C to 125°C l –20 50 mV 1.1V ≤ VADJ2/3 ≤ 5V, ILOAD = 1mA –40°C to 150°C l –6 15 mV 5V < VADJ2/3 ≤ 10V, ILOAD = 1mA –40°C to 150°C l –20 80 mV 3668fa For more information www.linear.com/LT3668 3 Document Outline Features Applications Description Typical Application Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Application Related Parts
