Datasheet RH3845MK DICE (Analog Devices) - 7
DescriptionRadiation Hardened High Voltage Synchronous Step-Down Controller
Pages / Page8 / 7 — rEvIsIon hIstory (Revision history begins at Rev C). REV. DATE. …
File Format / SizePDF / 166 Kb
rEvIsIon hIstory (Revision history begins at Rev C). REV. DATE. DESCRIPTION. PAGE NUMBER
rEvIsIon hIstory (Revision history begins at Rev C) REV DATE DESCRIPTION PAGE NUMBER
DICE/DWF SPECIFICATION
C 09/16 Removed VCC Current Limit, corrected Reverse Current Sense Voltage Offset from 10mV to 20mV, corrected FB Bias Current from maximum 50nA to ±100nA 2, 3, 4 Information furnished by Linear Technology Corporation is believed to be accurate and reliable. However, no responsibility is assumed for its use. Linear Technology Corporation makes no representa- tion that the interconnection of its circuits as described herein will not infringe on existing patent rights. 7 Document Outline Description DICE Pinout Absolute Maximum Ratings Table 1: DICE/DWF Electrical Test Limits Table 2: Electrical Characteristics Table 3: Electrical Characteristics Table 4: Electrical Test Requirements Total Dose Bias Circuit — Run Mode Total Dose Bias Circuit — Shutdown Mode Burn-In Circuit — Run Mode Typical Performance Characteristics
