LT3470A PIN FUNCTIONSSHDN (Pin 8): The SHDN pin is used to put the LT3470A in BOOST (Pin 3): The BOOST pin is used to provide a drive shutdown mode. Tie to ground to shut down the LT3470A. voltage, which is higher than the input voltage, to the Apply 2V or more for normal operation. If the shutdown internal bipolar NPN power switch. feature is not used, tie this pin to the VIN pin. BIAS (Pin 2): The BIAS pin connects to the internal boost NC (Pin 7): This pin can be left floating, connected to VIN, Schottky diode and to the internal regulator. Tie to VOUT or tied to GND. when VOUT > 2.5V or to VIN otherwise. When VBIAS > 3V the BIAS pin will supply current to the internal regulator. VIN (Pin 6): The VIN pin supplies current to the LT3470A’s internal regulator and to the internal power switch. This FB (Pin 1): The LT3470A regulates its feedback pin to pin must be locally bypassed. 1.25V. Connect the feedback resistor divider tap to this pin. Set the output voltage according to V GND (Pin 5): Tie the GND pin to a local ground plane OUT = 1.25V (1 + R1/R2) or R1 = R2 (V below the LT3470A and the circuit components. Return OUT/1.25 – 1). the feedback divider to this pin. Exposed Pad (Pin 9): Ground. Must be soldered to PCB. SW (Pin 4): The SW pin is the output of the internal power switch. Connect this pin to the inductor, catch diode and boost capacitor. BLOCK DIAGRAM VIN BIAS VIN C1 + – BOOST 500ns ONE SHOT R Qʹ C3 S Q – L1 SW VOUT C2 ENABLE + BURST MODE NC DETECT SHDN VREF 1.25V gm FB GND R2 R1 3470a BD 3470afb 7
