Datasheet LTC3810 (Analog Devices) - 3
Description | 100V Current Mode Synchronous Switching Regulator Controller |
Pages / Page | 38 / 3 — The. ELECTRICAL CHARACTERISTICS. denotes specifi cations which apply over … |
File Format / Size | PDF / 491 Kb |
The. ELECTRICAL CHARACTERISTICS. denotes specifi cations which apply over the full operating
LTC3810
The ELECTRICAL CHARACTERISTICS
denotes specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C (Note 2), INTVCC = DRVCC = VBOOST = VON = VRNG = SHDN = UVIN = VEXTVCC = VNDRV = 10V, VMODE/SYNC = VSENSE+ = VSENSE– = VBGRTN = VSW = 0V, unless otherwise specifi ed. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
∆V Feedback Voltage Line Regulation 7V < INTV FB,LINE CC < 14V (Note 4) l 0.002 0.02 %/V VSENSE(MAX) Maximum Current Sense Threshold VRNG = 2V, VFB = 0.76V 256 320 384 mV VRNG = 0V, VFB = 0.76V 70 95 120 mV VRNG = INTVCC, VFB = 0.76V 170 215 260 mV VSENSE(MIN) Minimum Current Sense Threshold VRNG = 2V, VFB = 0.84V –300 mV VRNG = 0V, VFB = 0.84V –85 mV VRNG = INTVCC, VFB = 0.84V –200 mV IVFB Feedback Current VFB = 0.8V 20 150 nA AVOL(EA) Error Amplifi er DC Open Loop Gain 65 100 dB fU Error Amp Unity-Gain Crossover (Note 6) 25 MHz Frequency VMODE/SYNC MODE/SYNC Threshold VMODE/SYNC Rising 0.75 0.8 0.85 V IMODE/SYNC MODE/SYNC Current MODE/SYNC = 10V 0 1 μA VSHDN Shutdown Threshold 1.2 1.5 2 V ISHDN SHDN Pin Input Current 0 1 μA VVINUV VIN Undervoltage Lockout VIN Rising l 0.86 0.88 0.92 V VIN Falling l 0.78 0.80 0.82 V Hysteresis 0.07 0.10 0.12 V VVCCUV INTVCC Undervoltage Lockout Linear Regulator Mode INTVCC Rising, INDRV = 100μA l 6.05 6.2 6.35 V External Supply Mode INTVCC Rising, NDRV = INTVCC = EXTVCC l 6.05 6.2 6.35 V Trickle-Charge Mode INTVCC Rising, NDRV = INTVCC, EXTVCC = 0 l 11.7 12 12.3 V INTVCC Falling 5.7 V
Oscillator and Phase-Locked Loop
tON On-Time ION = 100μA 1.55 1.85 2.15 μs ION = 300μA 515 605 695 ns tON(MIN) Minimum On-Time ION = 2000μA 100 ns tOFF(MIN) Minimum Off-Time 250 350 ns tON(PLL) tON Modulation Range by PLL Down Modulation ION = 100μA, VPLL/LPF = 0.6V 2.2 3.6 5 μs Up Modulation ION = 100μA, VPLL/LPF = 1.8V 0.6 1.2 1.8 μs IPLL/LPF Phase Detector Output Current Sinking Capability fPLLIN < fSW 15 μA Sourcing Capability fPLLIN > fSW –25 μA
Driver
IBG,PEAK BG Driver Peak Source Current VBG = 0V 1.5 2 A RBG,SINK BG Driver Pull-Down RDS(ON) 1 1.5 Ω ITG,PEAK TG Driver Peak Source Current VTG – VSW = 0V 1.5 2 A RTG,SINK TG Driver Pull-Down RDS(ON) 1 1.5 Ω
PGOOD Output
∆VFBOV PGOOD Upper Threshold VFB Rising 7.5 10 12.5 % PGOOD Lower Threshold VFB Falling –7.5 –10 –12.5 % ∆VFB,HYST PGOOD Hysteresis VFB Returning 1.5 3 % VPGOOD PGOOD Low Voltage IPGOOD = 5mA 0.3 0.6 V IPGOOD PGOOD Leakage Current VPGOOD = 5V 0 2 μA PG Delay PGOOD Delay VFB Falling 120 μs 3810fc 3
