Datasheet LT1977 (Analog Devices) - 8
DescriptionHigh Voltage 1.5A, 500kHz Step-Down Switching Regulator with 100µA Quiescent Current
Pages / Page24 / 8 — BLOCK DIAGRA. Figure 1. LT1977 Block Diagram
File Format / SizePDF / 334 Kb
BLOCK DIAGRA Figure 1 LT1977 Block Diagram
LT1977
W BLOCK DIAGRA
VIN INTERNAL REF SLOPE 4 2.4V COMP UNDERVOLTAGE LOCKOUT Σ + BIAS THERMAL 10 500kHz SHUTDOWN CURRENT OSCILLATOR COMP SYNC – 14 BOOST ANTISLOPE 6 SHDN COMP 15 + R SHDN SWITCH DRIVER COMP Q LATCH CIRCUITRY – S SW 2 1.3V CSS BURST MODE 9 SOFT-START DETECT FOLDBACK VC DETECT CLAMP FB – 12 ERROR + AMP 1.25V VC 11 PG 16 PGFB 13 + PG 1.2V CT COMP CLAMP 1.12V – GND 17 CT PGND 8 7 1977 BD
The LT1977 is a constant frequency, current mode buck delivered to the output rather than voltage. A voltage fed converter. This means that there is an internal clock and two system will have low phase shift up to the resonant fre- feedback loops that control the duty cycle of the power quency of the inductor and output capacitor, then an abrupt switch. In addition to the normal error amplifier, there is a 180° shift will occur. The current fed system will have 90° current sense amplifier that monitors switch current on a phase shift at a much lower frequency, but will not have the cycle-by-cycle basis. A switch cycle starts with an oscilla- additional 90° shift until well beyond the LC resonant fre- tor pulse which sets the RS latch to turn the switch on. When quency. This makes it much easier to frequency compen- switch current reaches a level set by the current compara- sate the feedback loop and also gives much quicker tran- tor the latch is reset and the switch turns off. Output volt- sient response. age control is obtained by using the output of the error Most of the circuitry of the LT1977 operates from an amplifier to set the switch current trip point. This technique internal 2.4V bias line. The bias regulator normally draws means that the error amplifier commands current to be 1977fa 8
