Datasheet LT1976, LT1976B (Analog Devices) - 10
DescriptionHigh Voltage 1.5A, 200kHz Step-Down Switching Regulator with 100µA Quiescent Current
Pages / Page28 / 10 — BLOCK DIAGRA. Figure 1. LT1976/LT1976B Block Diagram
File Format / SizePDF / 314 Kb
BLOCK DIAGRA Figure 1 LT1976/LT1976B Block Diagram
LT1976/LT1976B
W BLOCK DIAGRA
VIN INTERNAL REF SLOPE 4 2.4V COMP UNDERVOLTAGE LOCKOUT Σ + BIAS THERMAL 10 200kHz SHUTDOWN CURRENT OSCILLATOR COMP SYNC – 14 BOOST ANTISLOPE 6 SHDN COMP 15 + R SHDN SWITCH DRIVER COMP Q LATCH CIRCUITRY – S SW 2 1.3V BURST MODE CSS 9 SOFT-START DETECT LT1976 ONLY FOLDBACK VC DETECT CLAMP FB 12 – ERROR AMP 1.25V + VC 11 PG 16 PGFB 13 + PG 1.2V CT COMP CLAMP 1.12V – GND 17 CT PGND 8 7 1976 BD
The LT1976 is a constant frequency, current mode buck delivered to the output rather than voltage. A voltage fed converter. This means that there is an internal clock and two system will have low phase shift up to the resonant fre- feedback loops that control the duty cycle of the power quency of the inductor and output capacitor, then an abrupt switch. In addition to the normal error amplifier, there is a 180° shift will occur. The current fed system will have 90° current sense amplifier that monitors switch current on a phase shift at a much lower frequency, but will not have the cycle-by-cycle basis. A switch cycle starts with an oscilla- additional 90° shift until well beyond the LC resonant fre- tor pulse which sets the RS latch to turn the switch on. When quency. This makes it much easier to frequency compen- switch current reaches a level set by the current compara- sate the feedback loop and also gives much quicker tran- tor the latch is reset and the switch turns off. Output volt- sient response. age control is obtained by using the output of the error Most of the circuitry of the LT1976 operates from an amplifier to set the switch current trip point. This technique internal 2.4V bias line. The bias regulator normally draws means that the error amplifier commands current to be 1976bfg 10
