Datasheet LTC6432-15 (Analog Devices) - 2
Description100kHz to 1.4GHz Differential ADC Driver/IF Amplifier
Pages / Page20 / 2 — ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION …
ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION http://www.linear.com/product/LTC6432-15#orderinfo
ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION (Note 1) ORDER INFORMATION http://www.linear.com/product/LTC6432-15#orderinfo
LTC6432-15
Total Supply Voltage (V TOP VIEW CC to GND)...5.5V Amplifier Output Current (+OUT) ...105mA +IN GND V CC DNC DNC +FDBK Amplifier Output Current (–OUT) ...105mA 24 23 22 21 20 19 RF Input Power, Continuous, 50Ω (Note 2).. +15dBm DNC 1 18 +OUT RF Input Power, 100µs pulse, 50Ω (Note 2) ..+20dBm DNC 2 17 GND Operating Case Temperature DNC 3 25 16 DNC Range (T DNC 4 GND 15 T_DIODE CASE) ..–40°C to 85°C Storage Temperature Range .. –65°C to 150°C NFILT2 5 14 DNC NFILT1 6 13 –OUT Junction Temperature (TJ) .. 150°C Lead Temperature (Soldering, 10 sec) ...300°C 7 8 9 10 11 12 –IN GND V CC DNC DNC –FDBK UF PACKAGE 24-LEAD (4mm × 4mm) PLASTIC QFN TJMAX = 150°C, θJC = 40°C/W EXPOSED PAD (PIN 25) IS GND, MUST BE SOLDERED TO PCB. CASE TEMPERATURE IS MEASURED ON THE BACKSIDE OF THE PCB.
ORDER INFORMATION http://www.linear.com/product/LTC6432-15#orderinfo LEAD FREE FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE (TCASE)
LTC6432AIUF-15#PBF LTC6432AIUF-15#TRPBF 43215 24-Lead (4mm × 4mm) Plastic QFN –40°C to 85°C LTC6432BIUF-15#PBF LTC6432BIUF-15#TRPBF 43215 24-Lead (4mm × 4mm) Plastic QFN –40°C to 85°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/. Some packages are available in 500 unit reels through designated sales channels with #TRMPBF suffix. The LTC6432-15 is available in two grades. Grade A guarantees a minimum OIP3 at 150MHz while grade B does not. A- and B-grades are identified by a label on the shipping container.
DC ELECTRICAL CHARACTERISTICS The
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C, VCC = 5V, ZSOURCE = ZLOAD = 100Ω. Typical measured DC electrical performance using Test Circuit A (Note 3). SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VS Operating Supply Range 4.75 5 5.25 V IS,TOT Total Supply Current All VCC Pins Plus +OUT and –OUT. 145 166 195 mA l 110 220 mA IS,OUT Total Supply Current to OUT Pins Current to +OUT and –OUT 130 152 185 mA l 100 200 mA IVCC Current to VCC Pin Either VCC Pin May Be Used 13 14 17 mA l 12.5 17.5 mA 643215f 2 For more information www.linear.com/LTC6432-15 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information DC Electrical Characteristics AC Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Test Circuit A Operation Applications Information Differential S Parameters Package Description Typical Application Related Parts
