Datasheet LTC6430-15 (Analog Devices) - 8
DescriptionHigh Linearity Differential RF/IF Amplifier/ADC Driver
Pages / Page28 / 8 — Typical perForMance characTerisTics TA = 25°C, VCC = 5V, ZSOURCE = ZLOAD …
Typical perForMance characTerisTics TA = 25°C, VCC = 5V, ZSOURCE = ZLOAD = 100Ω,
LTC6430-15
Typical perForMance characTerisTics TA = 25°C, VCC = 5V, ZSOURCE = ZLOAD = 100Ω, unless otherwise noted (Note 3). Measurements are performed using Test Circuit A, measuring from 50Ω SMA to 50Ω SMA without de-embedding (Note 4). Output Power vs Input Power Over Frequency P1dB vs Frequency Total Current (ITOT) vs VCC
25 25 180 VCC = 5V TCASE = 25°C 24 ZIN = ZOUT = 100Ω 170 23 24 TA = 25°C 160 22 21 23 150 20 (mA) 140 19 P1dB (dBm) 22 I TOT 130 OUTPUT POWER (dBm) 18 120 17 21 110 16 15 20 100 2 3 4 5 6 7 8 9 10 11 12 0 100 200 300 400 500 600 700 800 900 1000 3 3.5 4 4.5 5 5.5 6 6.5 INPUT POWER (dBm) FREQUENCY (MHz) VCC (V) 643015 G18 643015 G19 643015 G20 100MHz, P1dB = 23.8dBm 200MHz, P1dB = 24.1dBm 400MHz, P1dB = 23.5dBm 600MHz, P1dB = 23.1dBm 800MHz, P1dB = 22.6dBm 1000MHz, P1dB = 22.3dBm
Total Current (ITOT) Total Current vs RF Input Power vs Case Temperature
170 175 150 170 165 130 160 110 (mA) I TOT 155 AL CURRENT (mA) 90 TOT 150 70 VCC = 5V 145 TA = 25°C VCC = 5V 50 140 –15 –10 –5 0 5 10 15 20 –60 –40 –20 0 20 40 60 80 100 RF INPUT POWER (dBm) CASE TEMPERATURE (°C) 643015 G21 643015 G22 643015f 8 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information DC Electrical Characteristics AC Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Test Circuit A Operation Applications Information Differential S Parameters Typical Applications Package Description Typical Application Related Parts
