Datasheet LTC6417 (Analog Devices) - 6
Description | 1.6GHz Low Noise High Linearity Differential Buffer/16-Bit ADC Driver with Fast Clamp |
Pages / Page | 32 / 6 — ac elecTrical characTerisTics. The. denotes the specifications which … |
File Format / Size | PDF / 1.4 Mb |
ac elecTrical characTerisTics. The. denotes the specifications which apply over the full operating
LTC6417
ac elecTrical characTerisTics The
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. V+ = 5V unless otherwise noted, GND = 0V, RLOAD = 500Ω,CLOAD = 6pF. VCM = 1.25V, CLHI = V+, PWRADJ = VCC, SHDN = 0V unless otherwise noted. VINCM is defined as (IN+ + IN–)/2. VOUTCM is defined as (OUT+ + OUT–)/2. VINDIFF is defined as (IN+ – IN–). VOUTDIFF is defined as (OUT+ – OUT–). See DC test circuit schematic. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS AC Linearity 10MHz Signal
HD3 Third Harmonic Distortion VOUTDIFF = 2.4VP-P, RL = 50Ω –89 dBc VOUTDIFF = 2.4VP-P –93 dBc IM3 Third Order Intermodulation Distortion VOUTDIFF = 2.4VP-P, RL = 50Ω –100 dBc VOUTDIFF = 2.4VP-P –110 dBc OIP3 Output Third Order Intercept VOUTDIFF = 2.4VP-P, RL = 50Ω 56 dBm P1dB Output 1dB Compression Point 16.1 dBm
70MHz Signal
HD3 Third Harmonic Distortion VOUTDIFF = 2.4VP-P, RL = 50Ω –74 dBc VOUTDIFF = 2.4VP-P –77 dBc IM3 Third Order Intermodulation Distortion VOUTDIFF = 2.4VP-P, RL = 50Ω –86 dBc VOUTDIFF = 2.4VP-P –96 dBc OIP3 Output Third Order Intercept VOUTDIFF = 2.4VP-P, RL = 50Ω 48 dBm P1dB Output 1dB Compression Point 15.8 dBm
140MHz Signal
HD3 Third Harmonic Distortion VOUTDIFF = 2.4VP-P, RL = 50Ω –69 dBc VOUTDIFF = 2.4VP-P –73 dBc IM3 Third Order Intermodulation Distortion VOUTDIFF = 2.4VP-P, RL = 50Ω –80 dBc VOUTDIFF = 2.4VP-P –91 dBc OIP3 Output Third Order Intercept VOUTDIFF = 2.4VP-P, RL = 50Ω 46 dBm P1dB Output 1dB Compression Point 15.8 dBm
200MHz Signal
HD3 Third Harmonic Distortion VOUTDIFF = 2.4VP-P, RL = 50Ω –68 dBc VOUTDIFF = 2.4VP-P –71 dBc IM3 Third Order Intermodulation Distortion VOUTDIFF = 2.4VP-P, RL = 50Ω –78 dBc VOUTDIFF = 2.4VP-P –87 dBc OIP3 Output Third Order Intercept VOUTDIFF = 2.4VP-P, RL = 50Ω 44 dBm P1dB Output 1dB Compression Point 15.8 dBm
240MHz Signal
HD3 Third Harmonic Distortion VOUTDIFF = 2.4VP-P, RL = 50Ω –67 dBc VOUTDIFF = 2.4VP-P –70 dBc IM3 Third Order Intermodulation Distortion VOUTDIFF = 2.4VP-P, RL = 50Ω –76 dBc VOUTDIFF = 2.4VP-P –85 dBc OIP3 Output Third Order Intercept VOUTDIFF = 2.4VP-P, RL = 50Ω 43 dBm P1dB Output 1dB Compression Point 15.7 dBm
300MHz Signal
HD3 Third Harmonic Distortion VOUTDIFF = 2.4VP-P, RL = 50Ω –66 dBc VOUTDIFF = 2.4VP-P –69 dBc 6417f 6 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information DC Electrical Characteristics AC Electrical Characteristics Typical Performance Characteristics Pin Functions DC Test Circuit Schematic Block Diagram Applications Information Package Description Typical Application Related Parts
