Datasheet LTC6409 (Analog Devices) - 3
Description10GHz GBW, 1.1nV/√Hz Differential Amplifier/ADC Driver
Pages / Page24 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes the specifications which apply …
File Format / SizePDF / 457 Kb
LTC6409
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. V+ = 5V, V– = 0V, VCM = VOCM = VICM = 1.25V, VSHDN = open. VS is defined as (V+ – V–). VOUTCM is defined as (V+OUT + V–OUT)/2. VICM is defined as (V+IN + V–IN)/2. VOUTDIFF is defined as (V+OUT – V–OUT). SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
enVOCM Common Mode Noise Voltage Density f = 10MHz 12 nV/√Hz VICMR Input Signal Common Mode Range VS = 3V l 0 1.5 V (Note 7) VS = 5V l 0 3.5 V CMRRI Input Common Mode Rejection Ratio VS = 3V, VICM from 0V to 1.5V l 75 90 dB (Note 8) (Input Referred) ΔVICM/ΔVOSDIFF VS = 5V, VICM from 0V to 3.5V l 75 90 dB CMRRIO Output Common Mode Rejection Ratio (Input VS = 3V, VOCM from 0.5V to 1.5V l 55 80 dB (Note 8) Referred) ΔVOCM/ΔVOSDIFF VS = 5V, VOCM from 0.5V to 3.5V l 60 85 dB PSRR Differential Power Supply Rejection (ΔVS/ΔVOSDIFF) VS = 2.7V to 5.25V l 60 85 dB (Note 9) PSRRCM Output Common Mode Power Supply Rejection VS = 2.7V to 5.25V l 55 70 dB (Note 9) (ΔVS/ΔVOSCM) VS Supply Voltage Range (Note 10) l 2.7 5.25 V GCM Common Mode Gain (ΔVOUTCM/ΔVOCM) VS = 3V, VOCM from 0.5V to 1.5V l 1 V/V VS = 5V, VOCM from 0.5V to 3.5V l 1 V/V ΔGCM Common Mode Gain Error, 100 × (GCM – 1) VS = 3V, VOCM from 0.5V to 1.5V l ±0.1 ±0.3 % VS = 5V, VOCM from 0.5V to 3.5V l ±0.1 ±0.3 % BAL Output Balance ΔVOUTDIFF = 2V (ΔVOUTCM/ ΔVOUTDIFF) Single-Ended Input l –65 –50 dB Differential Input l –70 –50 dB VOSCM Common Mode Offset Voltage (VOUTCM – VOCM) VS = 3V l ±1 ±5 mV VS = 5V l ±1 ±6 mV ΔVOSCM Common Mode Offset Voltage Drift l 4 µV/°C ΔT VOUTCMR Output Signal Common Mode Range VS = 3V l 0.5 1.5 V (Note 7) (Voltage Range for the VOCM Pin) VS = 5V l 0.5 3.5 V RINVOCM Input Resistance, VOCM Pin l 30 40 50 kΩ VOCM Self-Biased Voltage at the VOCM Pin VS = 3V, VOCM = Open 0.85 V VS = 5V, VOCM = Open l 0.9 1.25 1.6 V VOUT Output Voltage, High, Either Output Pin VS = 3V, IL = 0 l 1.85 2 V VS = 3V, IL = –20mA l 1.8 1.95 V VS = 5V, IL = 0 l 3.85 4 V VS = 5V, IL = –20mA l 3.8 3.95 V Output Voltage, Low, Either Output Pin VS = 3V, 5V; IL = 0 l 0.06 0.15 V VS = 3V, 5V; IL = 20mA l 0.2 0.4 V ISC Output Short-Circuit Current, Either Output Pin VS = 3V l ±50 ±70 mA (Note 11) VS = 5V l ±70 ±95 mA AVOL Large-Signal Open Loop Voltage Gain 65 dB IS Supply Current 52 56 mA l 58 mA ISHDN Supply Current in Shutdown VSHDN ≤ 0.6V l 100 500 µA RSHDN SHDN Pull-Up Resistor VSHDN = 0V to 0.5V l 115 150 185 kΩ VIL SHDN Input Logic Low l 0.6 V VIH SHDN Input Logic High l 1.4 V tON Turn-On Time 160 ns tOFF Turn-Off Time 80 ns 6409fb For more information www.linear.com/LTC6409 3 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Applications Information Typical Applications Package Description Revision History Typical Applications Related Parts Features Applications Typical Application Description Absolute Maximum Ratings Order Information Electrical Characteristics Pin Configuration Typical Performance Characteristics Pin Functions Block Diagram Applications Information Typical Applications Package Description Revision History Typical Applications Related Parts
