Datasheet LTC6410-6 (Analog Devices) - 3
DescriptionLow Distortion, Low Noise Differential IF Amplifier with Configurable Input Impedance
Pages / Page16 / 3 — 3V DC ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which …
File Format / SizePDF / 359 Kb
3V DC ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full
3V DC ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full
LTC6410-6
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. V+ = 3V, V– = 0V, SHDN = 2V, +IN is shorted to +TERM, –IN is shorted to –TERM, VBIAS = 1.5V, +IN = –IN = 1.5V, input source resistance (RS) is 25
Ω
on each input (50
Ω
differential), RL = 50
Ω
from +OUT to –OUT, unless otherwise noted. VBIAS is defi ned as the voltage on the VBIAS pin. VOUTCM is defi ned as (+OUT + –OUT)/2. VINCM is defi ned as (+IN + –IN)/2. VINDIFF is defi ned as (+IN – –IN). VOUTDIFF is defi ned as (+OUT – –OUT). See DC test circuit schematic. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
TC VOS Input Offset Voltage Drift l –0.3 μV/°C VOSINCM Common Mode Offset Voltage VOUTCM – VINCM –40 13 40 mV l –50 50 mV AV Internal Voltage Gain 2.7 V/V IVRMIN Input Common Mode Voltage Range, l 1.0 V (Min) IVRMAX Input Common Mode Voltage Range, l 2.0 V (Max) RINDIFF Differential Input Resistance VINDIFF = ±100mV (Note 4) 40 58 80 Ω l 30 100 Ω XINDIFF Differential Input Reactance f = 100MHz 1 pF RINCM Input Common Mode Resistance 1000 Ω CMRR Common Mode Rejection Ratio VBIAS = 1.5V, +IN = –IN = 1V to 2V, (ΔVOUTDIFF/Gain) l 45 60 dB RODIFF Differential Output Resistance VOUTDIFF = ±100mV (Note 4) 17 22 38 Ω l 13 47 Ω XOUTDIFF Differential Output Reactance f = 100MHz 10 nH ROUTCM Common Mode Output Resistance 7 Ω
Bias Voltage Control (VBIAS Pin)
GCM Common Mode Gain VBIAS = 1.2V to 1.8V (+IN and –IN fl oating), 0.7 0.86 1.0 V/V ΔVOUTCM/(0.6V) l 0.6 1.0 V/V VOCMMIN Output Common Mode Voltage l 1.0 1.2 V Adjustment Range, (Min) VOCMMAX Output Common Mode Voltage l 1.8 2.0 V Adjustment Range, (Max) VOSCM Output Common Mode Offset Voltage VOUTCM – VBIAS –200 100 300 mV l –400 400 mV RVOCM VBIAS Input Resistance 2.4 3.0 3.6 kΩ l 2.0 4.0 kΩ CVBIAS VBIAS Input Capacitance 3 pF
SHDN Pin
VIL SHDN Input Low Voltage l 0.8 1.0 V VIH SHDN Input High Voltage l 1.8 2 V IIL SHDN Input Low Current SHDN = 0.8V l –200 –85 0 μA IIH SHDN Input High Current SHDN = 2V l –150 –30 0 μA
Power Supply
VS Operating Range l 2.8 5.25 V IS Supply Current 104 130 mA l 140 mA ISSHDN Supply Current in Shutdown SHDN = 0.8V l 3 5 mA PSRR Power Supply Rejection Ratio V+ = 2.8V to 5.25V, VBIAS = +IN = –IN = V+/2 l 73 100 dB 64106fa 3
