Datasheet LTC6404 (Analog Devices) - 4
Description600MHz, Low Noise, High Precision Fully Differential Input/Output Amplifier/Driver
Pages / Page28 / 4 — LTC6404 DC ELECTRICAL CHARACTERISTICS The. denotes the specifi cations …
File Format / SizePDF / 347 Kb
LTC6404 DC ELECTRICAL CHARACTERISTICS The. denotes the specifi cations which apply over
LTC6404 DC ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over
LTC6404
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. V+ = 3V, V– = 0V, VCM = VOCM = VICM = Mid-Supply, VSHDN = OPEN, RL = OPEN, RBAL = 100k (See Figure 1). For the LTC6404-1: RI = 100Ω, RF = 100Ω. For the LTC6404-2: RI = 100Ω, R + F = 200Ω. For the LTC6404-4: RI = 100Ω, RF = 402Ω, unless otherwise noted. VS is defi ned (V+ – V–). VOUTCM = (VOUT + VOUT )/2. V + + ICM is defi ned (VIN + VIN )/2. VOUTDIFF is defi ned (VOUT – VOUT ). VINDIFF = (VINP – VINM) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
ΔVOSCM/ΔT Common Mode Offset Voltage Drift VS = 2.7V to 5.25V LTC6404-1 ±10 μV/°C LTC6404-2 ±20 μV/°C LTC6404-4 ±20 μV/°C VOUTCMR Output Signal Common Mode Range VS = 3V (Note 7) (Voltage Range for the VOCM Pin) LTC6404-1 l 1.1 2 V LTC6404-2 l 1.1 2 V LTC6404-4 l 1.1 1.7 V VS = 5V LTC6404-1 l 1.1 4 V LTC6404-2 l 1.1 4 V LTC6404-4 l 1.1 3.7 V RINVOCM Input Resistance, VOCM Pin LTC6404-1 l 15 23.5 32 kΩ LTC6404-2 l 8 14 20 kΩ LTC6404-4 l 4 7 10 kΩ VMID Voltage at the VOCM Pin VS = 3V l 1.45 1.5 1.55 V VOUT Output Voltage High, Either Output Pin (Note 10) VS = 3V, IL = 0mA l 325 550 mV VS = 3V, IL = 5mA l 360 600 mV VS = 3V, IL = 20mA l 480 750 mV VS = 5V, IL = 0mA l 460 700 mV VS = 5V, IL = 5mA l 500 750 mV VS = 5V, IL = 20mA l 650 1000 mV Output Voltage Low, Either Output Pin (Note 10) VS = 3V, IL = 0mA l 120 230 mV VS = 3V, IL = –5mA l 140 260 mV VS = 3V, IL = –20mA l 200 350 mV VS = 5V, IL = 0mA l 175 320 mV VS = 5V, IL = –5mA l 200 350 mV VS = 5V, IL = –20mA l 285 550 mV ISC Output Short-Circuit Current, Either Output Pin VS = 2.7V l ±35 ±60 mA (Note 11) VS = 3V l ±40 ±65 mA VS = 5V l ±55 ±85 mA AVOL Large-Signal Voltage Gain VS = 3V 90 dB VS Supply Voltage Range l 2.7 5.25 V IS Supply Current (LTC6404-1) VS = 2.7V, VSHDN = VS – 0.6V l 27.2 35.5 mA VS = 3V, VSHDN = VS – 0.6V l 27.3 35.5 mA VS = 5V, VSHDN = VS – 0.6V l 27.8 36.5 mA Supply Current (LTC6404-2) VS = 2.7V, VSHDN = VS – 0.6V l 29.7 38.5 mA VS = 3V, VSHDN = VS – 0.6V l 29.8 38.5 mA VS = 5V, VSHDN = VS – 0.6V l 30.4 39.5 mA Supply Current (LTC6404-4) VS = 2.7V, VSHDN = VS – 0.6V l 30.0 39 mA VS = 3V, VSHDN = VS – 0.6V l 30.2 39 mA VS = 5V, VSHDN = VS – 0.6V l 31.0 40 mA ISHDN Supply Current in Shutdown (LTC6404-1) VS = 2.7V, VSHDN = VS – 2.1V l 0.22 1 mA VS = 3V, VSHDN = VS – 2.1V l 0.25 1 mA VS = 5V, VSHDN = VS – 2.1V l 0.35 2 mA Supply Current in Shutdown (LTC6404-2) VS = 2.7V, VSHDN = VS – 2.1V l 0.22 1 mA VS = 3V, VSHDN = VS – 2.1V l 0.25 1 mA VS = 5V, VSHDN = VS – 2.1V l 0.35 2 mA Supply Current in Shutdown (LTC6404-4) VS = 2.7V, VSHDN = VS – 2.1V l 0.28 1.2 mA VS = 3V, VSHDN = VS – 2.1V l 0.30 1.2 mA VS = 5V, VSHDN = VS – 2.1V l 0.50 2.4 mA 6404f 4
