Datasheet LTC6401-26 (Analog Devices) - 3
Description1.6GHz Low Noise, Low Distortion Differential ADC Driver for DC-140MHz
Pages / Page16 / 3 — DC ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which …
File Format / SizePDF / 238 Kb
DC ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
DC ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
LTC6401-26
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. V+ = 3V, V– = 0V, +IN = –IN = VOCM = 1.25V,
E
N
A
B
L
E = 0V, No RL unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Input/Output Characteristic (+IN, –IN, +OUT, –OUT, +OUTF, –OUTF)
GDIFF Gain VIN = ±50mV Differential ● 25 26 27 dB TCGAIN Gain Temperature Drift VIN = ±50mV Differential ● 0.003 dB/°C VSWINGMIN Output Swing Low Each Output, VIN = ±200mV Differential ● 0.09 0.15 V VSWINGMAX Output Swing High Each Output, VIN = ±200mV Differential ● 2.3 2.43 V VOUTDIFFMAX Maximum Differential Output Swing 1dB Compressed ● 4.3 4.7 VP-P IOUT Output Current Drive Each Output, VIN = ±200mV, ● 10 mA VOUT > 2VP-P VOS Input Offset Voltage Differential ● –2.5 2.5 mV TCVOS Input Offset Voltage Drift Differential ● 1 μV/°C IVRMIN Input Common Mode Voltage Range, MIN 1 V IVRMAX Input Common Mode Voltage Range, MAX 1.6 V RINDIFF Input Resistance (+IN, –IN) Differential ● 42.5 50 57.5 Ω CINDIFF Input Capacitance (+IN, –IN) Differential, Includes Parasitic 1 pF ROUTDIFF Output Resistance (+OUT, –OUT) Differential ● 18 25 32 Ω ROUTFDIFF Filtered Output Resistance (+OUTF, –OUTF) Differential ● 85 100 115 Ω COUTFDIFF Filtered Output Capacitance (+OUTF, –OUTF) Differential, Includes Parasitic 2.7 pF CMRR Common Mode Rejection Ratio Input Common Mode Voltage ● 50 75 dB 1.1V to1.4V
Output Common Mode Control
GCM Common Mode Gain VOCM = 1V to 1.6V 1 V/V VOCMMIN Output Common Mode Range, MIN 1 V ● 1.1 V VOCMMAX Output Common Mode Range, MAX 1.6 V ● 1.5 V VOSCM Common Mode Offset Voltage VOCM = 1.1V to 1.5V ● –15 15 mV TCVOSCM Common Mode Offset Voltage Drift ● 3 μV/°C IVOCM VOCM Input Current ● 5 15 μA ⎯
E
N
A
B
L
E Pin
VIL ⎯E⎯N⎯A⎯B⎯L⎯E Input Low Voltage ● 0.8 V VIH ⎯E⎯N⎯A⎯B⎯L⎯E Input High Voltage ● 2.4 V IIL ⎯E⎯N⎯A⎯B⎯L⎯E Input Low Current ⎯E⎯N⎯A⎯B⎯L⎯E = 0.8V ● 0.5 μA IIH ⎯E⎯N⎯A⎯B⎯L⎯E Input High Current ⎯E⎯N⎯A⎯B⎯L⎯E = 2.4V ● 1.4 3 μA
Power Supply
VS Operating Supply Range ● 2.85 3 3.5 V IS Supply Current ⎯E⎯N⎯A⎯B⎯L⎯E = 0V, Both Inputs and ● 35 45 60 mA Outputs Floating ISHDN Shutdown Supply Current ⎯E⎯N⎯A⎯B⎯L⎯E = 3V, Both Inputs and ● 0.8 3 mA Outputs Floating PSRR Power Supply Rejection Ratio (Differential 2.85V to 3.5V ● 60 95.5 dB Outputs) 640126f 3
