Datasheet AD8375 (Analog Devices)
DescriptionUltralow Distortion IF VGA
Pages / Page24 / 1 — Ultralow Distortion IF VGA. Data Sheet. AD8375. FEATURES. FUNCTIONAL …
RevisionB
File Format / SizePDF / 814 Kb
Ultralow Distortion IF VGA. Data Sheet. AD8375. FEATURES. FUNCTIONAL BLOCK DIAGRAM. VPOS. COMM
Datasheet AD8375 Analog Devices, Revision: B
Ultralow Distortion IF VGA Data Sheet AD8375 FEATURES FUNCTIONAL BLOCK DIAGRAM VPOS COMM Bandwidth of 630 MHz (−3 dB) Gain range: −4 dB to +20 dB VCOM PWUP Step size: 1 dB ± 0.2 dB AD8375 Differential input and output OUT+ Noise figure: 8 dB @ maximum gain VIN+ OUT+ Output IP3 of ~50 dBm at 200 MHz POST-AMP
α
Output P1dB of 19 dBm at 200 MHz VIN– OUT– Provides constant SFDR vs. gain OUT– Parallel 5-bit control interface Power-down feature REGISTERS AND Single 5 V supply operation GAIN DECODER 24-lead, 4 mm × 4 mm LFCSP
1 -00
24
A4 A3 A2 A1 A0
067
Differential ADC drivers
Figure 1.
High IF sampling receivers Wideband multichannel receivers Instrumentation GENERAL DESCRIPTION
The AD8375 is a digitally controlled, variable gain, wide Fabricated on an Analog Devices, Inc., high speed SiGe process, bandwidth amplifier that provides precise gain control, high the AD8375 is supplied in a compact, thermally enhanced, IP3, and low noise figure. The excellent distortion performance 4 mm × 4 mm, 24-lead LFCSP package and operates over the and high signal bandwidth make the AD8375 an excellent gain temperature range of −40°C to +85°C. control device for a variety of receiver applications.
–40 65 -p p
Using an advanced high speed SiGe process and incorporating
–50 60 E
proprietary distortion cancellation techniques, the AD8375
@ 2V N T U O
achieves 50 dBm output IP3 at 200 MHz.
P /T T –60 55 U Bm
The AD8375 provides a broad 24 dB gain range with 1 dB
, O OIP3 3d Bc) –70 50 @
resolution. The gain is adjusted through a 5-pin control interface
d ( UT N P
and can be driven using standard TTL levels. The open-collector
T IO –80 45 U T
outputs provide a flexible interface, allowing the overall signal
R O ), O T HD2
gain to be set by the loading impedance. Thus, the signal
S –90 40 Bm d DI 3 (
voltage gain is directly proportional to the load.
IC N HD3 IP O –100 35 O
The AD8375 is powered on by applying the appropriate logic level to the PWUP pin. The quiescent current of the AD8375 is
HARM –110 30
52
40 60 80 100 120 140 160 180 200
0 4- typically 130 mA. When powered down, the AD8375 consumes
FREQUENCY (MHz)
72 06 less than 5 mA and offers excellent input-to-output isolation. Figure 2. Harmonic Distortion and Output IP3 vs. Frequency
Rev. B Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2007–2017 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT DESCRIPTION BASIC STRUCTURE Input System Output Amplifier Gain Control APPLICATIONS BASIC CONNECTIONS SINGLE-ENDED-TO-DIFFERENTIAL CONVERSION BROADBAND OPERATION ADC INTERFACING LAYOUT CONSIDERATIONS CHARACTERIZATION TEST CIRCUITS Differential-to-Differential Characterization EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
