Data SheetAD8375TYPICAL PERFORMANCE CHARACTERISTICS VS = 5 V, TA = 25°C, RS = RL = 150 Ω, 2 V p-p output, maximum gain unless otherwise noted. 251.046MHz 70MHz0.820140MHz 200MHz0.6150.4) B d0.2) 10R (B d (0RROIN5N E –0.2GAAI G0–0.4–0.6–5–0.8–10–1.0–405101520 03 –405101520 6 0 00 110001010001111010100010100000 4- 110001010001111010100010110100 4- 72 72 GAIN CODE 06 GAIN CODE 06 Figure 4. Gain vs. Gain Code at 46 MHz, 70 MHz, 140 MHz, and 200 MHz Figure 7. Gain Step Error, Frequency 140 MHz 2520dB2519dB18dB2017dBINPUT MAX16dBRATING15dB2014dBBOUNDARY1513dB12dB200MHz))11dB15140MHzB 1010dB70MHzdBm(9dBd46MHzIN8dBB (57dBGA1d6dBP 105dBO4dB03dB2dB1dB5–50dB–1dB–2dB–3dB–10–4dB0 07 101001000 004 0 4- –416111621 4- FREQUENCY (MHz) 72 72 06 GAIN (dB) 06 Figure 5. Gain vs. Frequency Response Figure 8. P1dB vs. Gain at 46 MHz, 70 MHz, 140 MHz, and 200 MHz 102525°C885°C6–40°C204) B d)(215Bm+25°CORdR+85°C0RB (–40°CE1dIN –2P 10OGA –4–65–8–100 8 –405101520 5 46100150200250300350400450500 00 00 4- 110001010001111010100010100000 4- FREQUENCY (MHz) 72 72 06 GAIN CODE 06 Figure 6. Gain Error over Temperature at 140 MHz Figure 9. P1dB vs. Frequency at Maximum Gain, Three Temperatures Rev. B | Page 7 of 24 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT DESCRIPTION BASIC STRUCTURE Input System Output Amplifier Gain Control APPLICATIONS BASIC CONNECTIONS SINGLE-ENDED-TO-DIFFERENTIAL CONVERSION BROADBAND OPERATION ADC INTERFACING LAYOUT CONSIDERATIONS CHARACTERIZATION TEST CIRCUITS Differential-to-Differential Characterization EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
