Datasheet AD8375 (Analog Devices) - 8
DescriptionUltralow Distortion IF VGA
Pages / Page24 / 8 — AD8375. Data Sheet. +25°C 20dB. V = +20dB. –40°C 20dB. +85°C 20dB. V = …
RevisionB
File Format / SizePDF / 814 Kb
AD8375. Data Sheet. +25°C 20dB. V = +20dB. –40°C 20dB. +85°C 20dB. V = +10dB. +25°C 0dB. AV = 20dB. –40°C 0dB. AV = 0dB. +85°C 0dB. m 47. B d
AD8375 Data Sheet +25°C 20dB V = +20dB –40°C 20dB +85°C 20dB V = +10dB +25°C 0dB AV = 20dB –40°C 0dB AV = 0dB +85°C 0dB m 47 B d
AD8375 Data Sheet 52 55 65 A +25°C 20dB 51 V = +20dB –40°C 20dB +85°C 20dB 50 A 50 60 V = +10dB +25°C 0dB AV = 20dB –40°C 0dB 49 AV = 0dB +85°C 0dB 48 45 55 ) ) ) m 47 m m B d B B d d 46 40 50 3 ( P A 3 ( 3 ( V = –4dB P AV = 0dB OI 45 OI OIP 44 35 45 43 42 30 40 41 40
9
25 35 30 50 70 90 110 130 150 170 190 210
-00
–3 –2 –1 0 1 2 3 4 5
2 01
FREQUENCY (MHz)
4- 06724 72
POUT PER TONE (dBm)
06 Figure 10. Output Third-Order Intercept at Four Gains, Figure 13. Output Third-Order Intercept vs. Power, Output Level at 3 dBm/Tone Frequency 140 MHz, Three Temperatures
52 –70 46MHz 51 70MHz AV = +20dB –75 140MHz 50 200MHz 49 –80 AV = +10dB 48 ) –85 m 47 B Bc) d AV = 0dB d 46 –90 3 ( D3 ( OIP 45 IM –95 44 AV = –4dB 43 –100 42 –105 41 40 –110
3
–4 –3 –2 –1 0 1 2 3 4 5 6
010 01 4-
–4 1 6 11 16
4-
P
27 72
OUT (dBm) GAIN (dB)
06 06 Figure 11. Output Third-Order Intercept vs. Power Figure 14. Two-Tone Output IMD vs. Gain at Four Gains, Frequency 140 MHz at 46 MHz, 70 MHz, 140 MHz, and 200 MHz, Output Level at 3 dBm/Tone
70 –70 65 –75 60 –80 –85 ) 55 m B +25°C Bc) +85°C d d 50 –90 3 ( –40°C P D3 ( +85°C –40°C OI IM 45 –95 +25°C 40 –100 35 –105 30
1
–110
4 01
40 60 80 100 120 140 160 180 200
01
4- 4- 72
FREQUENCY (MHz)
72
FREQUENCY (MHz)
06 06 Figure 12. Output Third-Order Intercept vs. Frequency, Figure 15. Two-Tone Output IMD vs. Frequency, Three Temperatures, Output Level at 3 dBm/Tone Three Temperatures, Output Level at 3 dBm/Tone Rev. B | Page 8 of 24 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT DESCRIPTION BASIC STRUCTURE Input System Output Amplifier Gain Control APPLICATIONS BASIC CONNECTIONS SINGLE-ENDED-TO-DIFFERENTIAL CONVERSION BROADBAND OPERATION ADC INTERFACING LAYOUT CONSIDERATIONS CHARACTERIZATION TEST CIRCUITS Differential-to-Differential Characterization EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
