Datasheet LT6411 (Analog Devices) - 3
Description | 650MHz Differential ADC Driver/Dual Selectable Gain Amplifier |
Pages / Page | 16 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply … |
File Format / Size | PDF / 371 Kb |
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
LT6411
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VS = ±5V, AV = 2, RL = 150
Ω
, CL = 1.5pF, VEN = 0.4V, VDGND = 0V, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
ISC Output Short-Circuit Current RL = 0Ω, VIN = ±1V ● ±50 ±105 mA SR Slew Rate ±1V on ±2V Output Step (Note 9) 1700 3300 V/µs –3dB BW Small-Signal –3dB Bandwidth VOUT = 200mVP-P, Single Ended 650 MHz 0.1dB BW Gain Flatness ±0.1dB Bandwidth VOUT = 200mVP-P, Single Ended 200 MHz FPBW Full Power Bandwidth 2V Differential VOUT = 2VP-P Differential, –3dB 600 MHz Full Power Bandwidth 2V VOUT = 2VP-P (Note 7) 270 525 MHz Full Power Bandwidth 4V VOUT = 4VP-P (Note 7) 263 MHz All Hostile Crosstalk f = 10MHz, VOUT = 2VP-P –75 dB f = 100MHz, VOUT = 2VP-P –50 dB ts Settling Time 0.1% to VFINAL, VSTEP = 2V 6 ns tr, tf Small-Signal Rise and Fall Time 10% to 90%, VOUT = 200mVP-P 550 ps dG Differential Gain (Note 8) 0.02 % dP Diffi erential Phase (Note 8) 0.01 Deg
The
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VCC = 5V, VEE = 0V, AV = 2, No RLOAD, VEN = 0.4V, VDGND = 0V, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Noise/Harmonic Performance Input/Output Characteristics 1MHz Signal
HD Second/Third Harmonic Distortion 2VP-P Differential –88 dBc 2VP-P Differential, RL = 200Ω Differential –87 dBc IMD31M Third-Order IMD 2VP-P Differential Composite, f1 = 0.95MHz, –93 dBc f2 = 1.05MHz 2VP-P Differential Composite, f1 = 0.95MHz, –91 dBc f2 = 1.05MHz, RL = 200Ω Differential OIP31M Output Third-Order Intercept Differential, f1 = 0.95MHz, f2 = 1.05MHz (Note 10) 49.5 dBm NF Noise Figure Single Ended 25.1 dB en1M Input Referred Noise Voltage Density 8 nV/√Hz P1dB 1dB Compression Point (Note 10) 19.5 dBm
10MHz Signal
HD Second/Third Harmonic Distortion 2VP-P Differential –85 dBc 2VP-P Differential, RL = 200Ω Differential –76 dBc IMD310M Third-Order IMD 2VP-P Differential Composite, RL = 1k, –92 dBc f1 = 9.5MHz, f2 = 10.5MHz 2VP-P Differential Composite, f1 = 9.5MHz, –89 dBc f2 = 10.5MHz, RL = 200Ω Differential OIP310M Output Third-Order Intercept Differential, f1 = 9.5MHz, f2 = 10.5MHz (Note 10) 49 dBm NF Noise Figure Single Ended 24.7 dB en10M Input Referred Noise Voltage Density 7.7 nV/√Hz P1dB 1dB Compression Point (Note 10) 19.5 dBm 6411f 3
