Datasheet LT6402-6 (Analog Devices) - 2
Description300MHz Low Distortion, Low Noise Differential Amplifier/ADC Driver (AV = 6dB)
Pages / Page16 / 2 — ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION. …
File Format / SizePDF / 238 Kb
ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION. LEAD FREE FINISH. TAPE AND REEL. PART MARKING
ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION (Note 1) ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING
LT6402-6
TOP VIEW Total Supply Voltage (VCCA/VCCB/VCCC to VEEA/VEEB/VEEC) ...5.5V +INA +INB –INA –INB Input Current (+INA, –INA, +INB, –INB, 16 15 14 13 V 1 12 V V CCC EEC OCM, ENABLE) ..±10mA V 2 11 OCM ENABLE Output Current (Continuous) 17 VCCA 3 10 VCCB +OUT, –OUT ...±100mA VEEA 4 9 VEEB +OUTFILTERED, –OUTFILTERED ..±30mA 5 6 7 8 Output Short-Circuit Duration (Note 2) .. Indefi nite Operating Temperature Range (Note 3).. –40°C to 85°C +OUT –OUT Specifi ed Temperature Range (Note 4) .. –40°C to 85°C +OUTFILTERED –OUTFILTERED Storage Temperature Range ... –65°C to 125°C UD PACKAGE Junction Temperature ... 125°C 16-LEAD (3mm × 3mm) PLASTIC QFN TJMAX = 125°C, θJA = 68°C/W, θJC = 4.2°C/W EXPOSED PAD IS VEE (PIN 17) MUST BE SOLDERED TO THE PCB
PACKAGE DESCRIPTION TEMPERATURE RANGE
LT6402CUD-6#PBF LT6402CUD-6#TRPBF LBZZ 16-Lead (3mm × 3mm) Plastic QFN –40°C to 85°C LT6402IUD-6#PBF LT6402IUD-6#TRPBF LBZZ 16-Lead (3mm × 3mm) Plastic QFN –40°C to 85°C
LEAD BASED FINISH TAPE AND REEL PART MARKING
LT6402CUD-6 LT6402CUD-6#TR LBZZ 16-Lead (3mm × 3mm) Plastic QFN –40°C to 85°C LT6402IUD-6 LT6402IUD-6#TR LBZZ 16-Lead (3mm × 3mm) Plastic QFN –40°C to 85°C Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. *The temperature grade is identifi ed by a label on the shipping container. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifi cations, go to: http://www.linear.com/tapeandreel/
The DC ELECTRICAL CHARACTERISTICS
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VCCA = VCCB = VCCC = 5V, VEEA = VEEB = VEEC = 0V, ENABLE = 0.8V, +INA shorted to +INB (+IN), –INA shorted to –INB (–IN), VOCM = 2.2V, Input common mode voltage = 2.2V, no RLOAD unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Input/Output Characteristics (+INA, +INB, –INA, –INB, +OUT, –OUT, +OUTFILTERED, –OUTFILTERED)
GDIFF Gain Differential (+OUT, –OUT), VIN = ±800mV Differential l 5.8 6 6.3 dB VSWINGMIN Single-Ended +OUT, –OUT, +OUTFILTERED, 0.25 0.35 V –OUTFILTERED, VIN = ±2.2V Differential l 0.5 V VSWINGMAX Single-Ended +OUT, –OUT, +OUTFILTERED, 3.4 3.6 V –OUTFILTERED, VIN = ±2.2V Differential l 3.3 V VSWINGDIFF Output Voltage Swing Differential (+OUT, –OUT), VIN = ±2.2V Differential 6.1 7 VP-P l 5.6 VP-P IOUT Output Current Drive l ±30 ±35 mA VOS Input Offset Voltage –6.5 1 6.5 mV l –10 10 mV 64026fa 2
