Datasheet AD8368 (Analog Devices) - 5
Description800 MHz, Linear-in-dB VGA with AGC Detector
Pages / Page20 / 5 — Data Sheet. AD8368. ABSOLUTE MAXIMUM RATINGS Table 3. Parameter. Rating. …
RevisionC
File Format / SizePDF / 743 Kb
Data Sheet. AD8368. ABSOLUTE MAXIMUM RATINGS Table 3. Parameter. Rating. ESD CAUTION
Data Sheet AD8368 ABSOLUTE MAXIMUM RATINGS Table 3 Parameter Rating ESD CAUTION
Data Sheet AD8368 ABSOLUTE MAXIMUM RATINGS Table 3.
Stresses at or above those listed under Absolute Maximum
Parameter Rating
Ratings may cause permanent damage to the product. This is a Supply Voltage (VPSO, VPSI) 5.5 V stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational ENBL and MODE Select Voltage 5.5 V section of this specification is not implied. Operation beyond RF Input Level 20 dBm the maximum operating conditions for extended periods may Internal Power Dissipation 440 mW affect product reliability. θJA 52°C/W Maximum Junction Temperature 125°C Operating Temperature Range −40°C to +85°C
ESD CAUTION
Storage Temperature Range −65°C to +150°C Lead Temperature (Soldering, 60 sec) 300°C Rev. C | Page 5 of 20 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT DESCRIPTION INPUT ATTENUATOR AND INTERPOLATOR FIXED-GAIN STAGE AND OUTPUT BUFFER OUTPUT OFFSET CORRECTION INPUT AND OUTPUT IMPEDANCES GAIN CONTROL INTERFACE APPLICATIONS INFORMATION VGA OPERATION AGC OPERATION STABILITY AND LAYOUT CONSIDERATIONS EVALUATION BOARD OUTLINE DIMENSIONS ORDERING GUIDE
