Datasheet AD8350 (Analog Devices) - 7
DescriptionLow Distortion 1.0 GHz Differential Amplifier
Pages / Page14 / 7 — AD8350. 7.5. INPUT REFERRED. 5.0. 2.5. VCC = 10V. –2.5. NOISE FIGURE – …
RevisionC
File Format / SizePDF / 247 Kb
AD8350. 7.5. INPUT REFERRED. 5.0. 2.5. VCC = 10V. –2.5. NOISE FIGURE – dB. CC = 5V. VCC = 5V. –5.0. 1dB COMPRESSION – dBm (Re: 50. –7.5. 100. 200
AD8350 7.5 INPUT REFERRED 5.0 2.5 VCC = 10V –2.5 NOISE FIGURE – dB CC = 5V VCC = 5V –5.0 1dB COMPRESSION – dBm (Re: 50 –7.5 100 200
AD8350 7.5 10 10 INPUT REFERRED ) 5.0 9 9 2.5 VCC = 10V 8 8 VCC = 10V 0 VCC = 10V 7 7 –2.5 NOISE FIGURE – dB V NOISE FIGURE – dB CC = 5V V 6 6 VCC = 5V –5.0 CC = 5V 1dB COMPRESSION – dBm (Re: 50 –7.5 5 5 0 100 200 300 400 500 600 0 50 100 150 200 250 300 350 400 450 500 0 50 100 150 200 250 300 350 400 450 500 FREQUENCY – MHz FREQUENCY – MHz FREQUENCY – MHz
TPC 19. AD8350-20 1 dB Compres- TPC 20. AD8350-15 Noise Figure TPC 21. AD8350-20 Noise Figure sion vs. Frequency vs. Frequency vs. Frequency
25 100 –20 AD8350-20 VCC = 5V 20 50 –30 VOUT + (VCC = 5V) 15 0 –40 10 AD8350-15 VOUT – (VCC = 5V) 5 –50 –50 AD8350-20 0 GAIN – dB –100 V –60 OUT + (VCC = 10V) PSRR – dB –5 –70 AD8350-15 OUTPUT OFFSET – mV –150 –10 VOUT – (VCC = 10V) –200 –80 –15 –20 –250 –90 1 2 3 4 5 6 7 8 9 10 –40 –20 0 20 40 60 80 1 10 100 1k VCC – Volts TEMPERATURE – C FREQUENCY – MHz
TPC 22. AD8350 Gain (S21) vs. TPC 23. AD8350 Output Offset Volt- TPC 24. AD8350 PSRR vs. Frequency Supply Voltage age vs. Temperature
–20 VCC = 5V 500mV VCC = 5V –30 AD8350-20 VOUT –40 –50 –60 AD8350-15 PSRR – dB –70 ENBL –80 5V 30ns –90 1 10 100 1k FREQUENCY – MHz
TPC 25. AD8350 CMRR vs. Frequency TPC 26. AD8350 Power-Up/Down Response Time REV. C –7–
