AD8350APPLICATIONSCLACCS/2ACLS/2Using the AD8350 Figure 1 shows the basic connections for operating the AD8350. 8765R A single supply in the range 5 V to 10 V is required. The power S/2AD8350 supply pin should be decoupled using a 0.1 μF capacitor. The C–PCP ENBL pin is tied to the positive supply or to 5 V (when V VSRLOAD CC = + 10 V) for normal operation and should be pulled to ground to put the device in sleep mode. Both the inputs and the outputs RS/21234 have dc bias levels at midsupply and should be ac-coupled. Also shown in Figure 1 are the impedance balancing requirements, LS/2CLS/2ACCAC either resistive or reactive, of the input and output. With an 0.1F input and output impedance of 200 Ω, the AD8350 should be ENBL (5V) driven by a 200 Ω source and loaded by a 200 Ω impedance. A +VS (5V TO 10V) reactive match can also be implemented. Figure 3. Reactively Matching the Input and Output C2C40.001SOURCEF0.001FLOADLCACCACLZ = 100SS8765AD83508765RS–AD8350Z = 200+C–CVPPSRLOAD+1234Z = 1001234C1C30.001F0.001FC5CC0.1FACACENBL (5V)0.1F+VENBL (5V)S (5V TO 10V) Figure 1. Basic Connections for Differential Drive +VS (5V TO 10V) Figure 4. Single-Ended Equivalent Circuit Figure 2 shows how the AD8350 can be driven by a single- ended source. The unused input should be ac-coupled to ground. When the source impedance is smaller than the load impedance, When driven single-endedly, there will be a slight imbalance in a step-up matching network is required. A typical step-up network the differential output voltages. This will cause an increase in is shown on the input of the AD8350 in Figure 3. For purely the second order harmonic distortion (at 50 MHz, with V resistive source and load impedances the resonant approach may CC = 10 V and V be used. The input and output impedance of the AD8350 can be OUT = 1 V p-p, –59 dBc was measured for the second harmonic on AD8350-15). modeled as a real 200 Ω resistance for operating frequencies less than 100 MHz. For signal frequencies exceeding 100 MHz, classi- LOAD cal Smith Chart matching techniques should be invoked in order to deal with the complex impedance relationships. Detailed S C2C487650.001F0.001F parameter data measured differentially in a 200 Ω system can be AD8350 found in Tables II and III. –Z = 200 For the input matching network the source resistance is less + than the input resistance of the AD8350. The AD8350 has a nominal 200 Ω input resistance from Pins 1 to 8. The reactance 1234 of the ac-coupling capacitors, CAC, should be negligible if 100 nF SOURCE capacitors are used and the lowest signal frequency is greater Z = 200C1C3 than 1 MHz. If the series reactance of the matching network 0.001F0.001FC5 inductor is defined to be XS = 2 π f LS, and the shunt reactance ENBL (5V)0.1F of the matching capacitor to be XP = (2 π f CP)–1, then: +VS (5V TO 10V) RS RLOAD RS Figure 2. Basic Connections for Single-Ended Drive X = × where = × S XP RLOAD (1) XP RLOAD – RS Reactive Matching In practical applications, the AD8350 will most likely be matched For a 70 MHz application with a 50 Ω source resistance, and using reactive matching components as shown in Figure 3. assuming the input impedance is 200 Ω, or RLOAD = RIN = 200 Ω, Matching components can be calculated using a Smith Chart or then XP = 115.5 Ω and XS = 86.6 Ω, which results in the follow- by using a resonant approach to determine the matching network ing component values: that results in a complex conjugate match. In either situation, CP = (2 π × 70 × 106 × 115.5)–1 = 19.7 pF and the circuit can be analyzed as a single-ended equivalent circuit to ease calculations as shown in Figure 4. LS = 86.6 × (2 π × 70 × 106)–1 = 197 nH –8– REV. C
