Datasheet LT6210, LT6211 (Analog Devices) - 5
DescriptionSingle Programmable Supply Current, R-R Output, Current Feedback Amplifiers
Pages / Page18 / 5 — e lecTrical characTerisTics (IS = 3mA per Amplifier) The. denotes the …
File Format / SizePDF / 354 Kb
e lecTrical characTerisTics (IS = 3mA per Amplifier) The. denotes the specifications which
e lecTrical characTerisTics (IS = 3mA per Amplifier) The denotes the specifications which
LT6210/LT6211
denotes the specifications which apply over the specified operating temperature range, otherwise specifications are at TA = 25°C. For V+ = 5V, V– = –5V: RSET = 56k to ground, AV = +2, RF = RG = 1.1k, RL = 150Ω; For V+ = 3V, V– = 0V: RSET = 10k to V–, AV = +2, RF = 1.27k, RG = 1.27k to 1.5V, RL = 150Ω to 1.5V unless otherwise specified. V+ = 5V, V– = –5V, IS = 3mA V+ = 3V, V– = 0V, IS = 3mA SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
PSRR Power Supply Rejection Ratio VS = ±1.5V to ±6V (Note 6) l 60 85 60 85 dB –IPSRR Inverting Input Current Power VS = ±1.5V to ±6V (Note 6) 1.5 ±7 1.5 ±7 µA/V Supply Rejection l ±8 ±8 µA/V IS Supply Current per Amplifier 3 4.1 3 4.1 mA l 4.55 4.4 mA IOUT Maximum Output Current RL = 0Ω (Notes 7, 11) l ±70 ±45 mA R – OL Transimpedance, ∆VOUT/∆IIN VOUT = V+ – 1.2V to V– + 1.2V 65 120 65 120 kΩ SR Slew Rate (Note 8) 450 600 150 V/µs tpd Propagation Delay 50% VIN to 50% VOUT, 3.1 4.7 ns 100mV + – P-P, Larger of tpd , tpd BW –3dB Bandwidth <1dB Peaking, AV = 1 100 70 MHz ts Settling Time To 0.1% of VFINAL, VSTEP = 2V 20 25 ns tf, tr Small-Signal Rise and Fall Time 10% to 90%, VOUT = 100mVP-P 3 5.6 ns dG Differential Gain (Note 9) 0.35 0.42 % dP Differential Phase (Note 9) 0.30 0.44 Deg HD2 2nd Harmonic Distortion f = 1MHz, VOUT = 2VP-P –65 –60 dBc HD3 3rd Harmonic Distortion f = 1MHz, VOUT = 2VP-P –65 –65 dBc
(IS = 300µA per Amplifier) The
denotes the specifications which apply over the specified operating temperature range, otherwise specifications are at TA = 25°C. For V+ = 5V, V– = –5V: RSET = 1M to ground, AV = +2, RF = RG = 11k, RL = 1k; For V+ = 3V, V– = 0V: RSET = 270k to V–, AV = +2, RF = 9.31k, RG = 9.31k to 1.5V, RL = 1k to 1.5V unless otherwise specified. V+ = 5V, V– = –5V, IS = 300µA V+ = 3V, V– = 0V, IS = 300µA SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
VOS Input Offset Voltage –1 ±4.5 –1.5 ±4.5 mV l ±8 ±8 mV I + IN Noninverting Input Current 0.2 ±1 0.2 ±1 µA l ±2 ±1.5 µA I – IN Inverting Input Current –3 ±8.5 –0.5 ±3 µA l ±11 ±4.5 µA en Input Noise Voltage Density f = 1kHz, RF = 13k, 13.5 13.5 nV/√Hz RG = 681Ω, RS = 0Ω +in Input Noise Current Density f = 1kHz 0.75 0.75 pA/√Hz –in Input Noise Current Density f = 1kHz 5 5 pA/√Hz R + IN Noninverting Input Resistance VIN = V+ – 1.2V to V– + 1.2V l 1 25 1 15 MΩ (Note 8) C + IN Noninverting Input Capacitance f = 100kHz 2 2 pF VINH Input Voltage Range, High (Note 10) l 3.8 4.1 1.8 2.1 V VINL Input Voltage Range, Low (Note 10) l –4.1 –3.8 0.9 1.2 V VOUTH Output Voltage Swing, High RL = 1k (Note 11) 4.75 4.85 2.75 2.85 V l 4.7 2.7 V VOUTL Output Voltage Swing, Low RL = 1k (Note 11) –4.95 –4.85 0.05 0.15 V l –4.8 0.2 V 62101fc 5 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical AC Performance Typical Performance Characteristics Applications Information Typical Applications Simplified Schematic Package Description Revision History Typical Application Related Parts
