LT1253/LT1254 UUWUAPPLICATIO S I FOR ATIO As a guideline to help in the selection of the LT1253/ MAX POWER LT1254, the following table describes the maximum sup- at MAX TA ply voltage that can be used with each part based on the LT1253CN8 VS < ±14 (Abs Max) 0.800W following assumptions: LT1253CS8 VS < ±10.6 0.533W 1. The maximum ambient is 70°C. LT1254CN VS < ±11.4 1.143W 2. The load is a double-terminated video cable, 150Ω. LT1254CS VS < ±7.6 0.727W 3. The maximum output voltage is 2V (peak or DC). WWSI PLIFIED SCHE ATICOne Amplifier V+ +IN –IN VOUT V– LT1253/54 • SS UPACKAGE DESCRIPTIODimensions in inches (millimeters) unless otherwise noted.N8 Package8-Lead Plastic DIP 0.400 (10.160) 0.300 – 0.320 0.045 – 0.065 0.130 ± 0.005 MAX (7.620 – 8.128) (1.143 – 1.651) (3.302 ± 0.127) 8 7 6 5 0.065 0.250 ± 0.010 (1.651) 0.009 – 0.015 TYP (6.350 ± 0.254) 0.125 (0.229 – 0.381) (3.175) 0.020 +0.025 0.045 ± 0.015 MIN (0.508) 0.325 1 2 3 4 –0.015 MIN (1.143 ± 0.381) +0.635 8.255 ( ) –0.381 0.100 ± 0.010 0.018 ± 0.003 (2.540 ± 0.254) (0.457 ± 0.076) N8 0392 Information furnished by Linear Technology Corporation is believed to be accurate and reliable. However, no responsibility is assumed for its use. Linear Technology Corporation makes no represen- tation that the interconnection of its circuits as described herein will not infringe on existing patent rights. 7
