Datasheet LT1252 (Analog Devices) - 3
Description | Low Cost Video Amplifier |
Pages / Page | 8 / 3 — ELECTRICAL CHARACTERISTICS 0. C, VS =. 5V to. 12V, unless otherwise … |
File Format / Size | PDF / 200 Kb |
ELECTRICAL CHARACTERISTICS 0. C, VS =. 5V to. 12V, unless otherwise noted. SYMBOL. PARAMETER. CONDITIONS. MIN. TYP. MAX. UNITS. Note 1:
LT1252
C
TA
70
C, VS =
5V to
12V, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
tr Small-Signal Rise Time VS = ±12V, AV = 2 3.5 ns Rise and Fall Time VS = ±5V, AV = 2, VOUT = 1VP-P 5.2 ns tp Propagation Delay VS = ±5V, AV = 2 3.5 ns
Note 1:
A heat sink may be required to keep the junction temperature LT1252CN8: TJ = TA + (PD × 100°C/W) below absolute maximum when the output is shorted indefinitely. LT1252CS8: TJ = TA + (PD × 150°C/W)
Note 2:
TJ is calculated from the ambient temperature TA and power dissipation PD according to the following formulas:
W U TYPICAL AC PERFOR A CE BANDWIDTH SMALL SIGNAL SMALL SIGNAL SMALL SIGNAL VS AV RL RF RG – 3dB BW (MHz) – 0.1dB BW (MHz) PEAKING (dB)
±12 1 150 2370 None 282 45 1.9 ±12 – 1 1000 1100 1100 58 17 0.1 ±12 – 1 150 909 909 73 34 0.1 ±12 2 1000 1210 1210 253 20 0.1 ±12 2 150 909 909 142 38 0.1 ±12 5 1000 1000 249 73 25 0.1 ±12 5 150 866 215 75 31 0.1 ±12 10 1000 909 100 67 26 0.1 ±12 10 150 768 84.5 69 32 0.1 ±5 1 1000 2210 None 260 10 2.4 ±5 1 150 1300 None 232 50 0.8 ±5 – 1 1000 1000 1000 50 11 0.1 ±5 – 1 150 732 732 69 34 0.1 ±5 2 1000 909 909 133 24 0.1 ±5 2 150 787 787 100 30 0.1 ±5 5 1000 825 205 62 21 0.1 ±5 5 150 698 174 66 30 0.1 ±5 10 1000 750 82.5 58 22 0.1 ±5 10 150 619 68.1 60 30 0.1
NTSC VIDEO (Note 1) DIFFERENTIAL DIFFERENTIAL VS AV RL RF RG GAIN PHASE
±12 2 1000 1000 1000 0.02% 0.02° ±12 2 150 1000 1000 0.03% 0.04° ±5 2 1000 1000 1000 0.02% 0.08° ±5 2 150 1000 1000 0.01% 0.09°
Note 1:
Differential Gain and Phase are measured using a Tektronix TSG amplifier stages were cascaded giving an effective resolution of 0.01% and 120 YC/NTSC signal generator and a Tektronix 1780R Video Measurement 0.01°. Set. The resolution of this equipment is 0.1% and 0.1°. Ten identical 3
