Datasheet LT1217 (Analog Devices) - 2
DescriptionLow Power 10MHz Current Feedback Amplifier
Pages / Page8 / 2 — ABSOLUTE. AXI U. R TI GS. PACKAGE/ORDER I FOR ATIO. ELECTRICAL CHAR C. A …
File Format / SizePDF / 221 Kb
ABSOLUTE. AXI U. R TI GS. PACKAGE/ORDER I FOR ATIO. ELECTRICAL CHAR C. A TERISTICS VS =. 15V, TA = 0. C to 70. C unless otherwise noted
ABSOLUTE AXI U R TI GS PACKAGE/ORDER I FOR ATIO ELECTRICAL CHAR C A TERISTICS VS = 15V, TA = 0 C to 70 C unless otherwise noted
LT1217
W W W U U W U ABSOLUTE AXI U A R TI GS PACKAGE/ORDER I FOR ATIO
Supply Voltage .. ±18V TOP VIEW ORDER PART Input Current .. ±10mA NUMBER Input Voltage .. Equal to Supply Voltage NULL 1 8 SHUTDOWN –IN 2 7 + Output Short Circuit Duration (Note 1) ... Continuous V LT1217CN8 +IN 3 6 OUT Operating Temperature Range ... 0°C to 70°C LT1217CS8 V – 4 5 NULL Storage Temperature Range ... – 65°C to 150°C S8 PART MARKING Junction Temperature ... 150°C N8 PACKAGE S8 PACKAGE 8-LEAD PLASTIC DIP 8-LEAD PLASTIC SOIC Lead Temperature (Soldering, 10 sec.)... 300°C LT1217 • POI01 1217
15V, TA = 0
C to 70
C unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage VCM = 0V ● ±1 ±3 mV IIN+ Non-Inverting Input Current VCM = 0V ● ±100 ±500 nA IIN– Inverting Input Current VCM = 0V ● ±100 ±500 nA en Input Noise Voltage Density f = 1kHz, RF = 1k, RG = 10Ω 6.5 nV/√Hz in Input Noise Current Density f = 1kHz, RF = 1k, RG = 10Ω 0.7 pA/√Hz RIN Input Resistance VIN = ±10V ● 20 100 MΩ CIN Input Capacitance 1.5 pF Input Voltage Range ● ±10 ±12 V CMRR Common Mode Rejection Ratio VCM = ±10V ● 60 66 dB Inverting Input Current Common Mode Rejection VCM = ±10V ● 5 20 nA/V PSRR Power Supply Rejection Ratio VS = ±4.5V to ±18V ● 68 76 dB Non-Inverting Input Current Power Supply Rejection VS = ±4.5V to ±18V ● 2 20 nA/V Inverting Input Current Power Supply Rejection VS = ±4.5V to ±18V ● 10 50 nA/V AV Large Signal Voltage Gain RLOAD = 2k, VOUT = ±10V ● 90 105 dB RLOAD = 400Ω, VOUT = ±10V ● 70 dB ROL Transresistance, ∆VOUT/∆IIN– RLOAD = 2k, VOUT = ±10V ● 5 45 MΩ RLOAD = 400Ω, VOUT = ±10V ● 1.5 MΩ VOUT Output Swing RLOAD = 2k ● ±12 ±13 V RLOAD = 200Ω ● ±10 V IOUT Output Current RLOAD = 0Ω ● 50 100 mA SR Slew Rate (Note 2, 3) RF = 3k, RG = 3k ● 100 500 V/µs BW Bandwidth RF = 3k, RG = 3k, VOUT = 100mV 10 MHz tr Rise Time, Fall Time (Note 3) RF = 3k, RG = 3k, VOUT = 1V ● 30 40 ns tPD Propagation Delay RF = 3k, RG = 3k, VOUT = 1V 25 ns Overshoot RF = 3k, RG = 3k, VOUT = 1V 5 % ts Settling Time, 0.1% RF = 3k, RG = 3k, VOUT = 10V 280 ns IS Supply Current VIN = 0V ● 1 2 mA Supply Current, Shutdown Pin 8 Current = 50µA ● 350 1000 µA The ● denotes specifications which apply over the operating temperature
Note 2:
Non-Inverting operation, VOUT = ±10V, measured at ±5V. range.
Note 3:
AC parameters are 100% tested on the plastic DIP packaged parts
Note 1:
A heat sink may be required. (N suffix), and are sample tested on every lot of the SO packaged parts (S suffix). 2
