Datasheet LT1630, LT1631 (Analog Devices) - 7
Description30MHz, 10V/µs, Dual/Quad Rail-to-Rail Input and Output Precision Op Amps
Pages / Page20 / 7 — TA = 25°C, VS = ±15V, VCM = 0V, VOUT = 0V, unless otherwise noted. …
File Format / SizePDF / 367 Kb
TA = 25°C, VS = ±15V, VCM = 0V, VOUT = 0V, unless otherwise noted. SYMBOL. PARAMETER. CONDITIONS. MIN. TYP. MAX. UNITS
TA = 25°C, VS = ±15V, VCM = 0V, VOUT = 0V, unless otherwise noted SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
LT1630/LT1631 e lecTrical characTerisTics
TA = 25°C, VS = ±15V, VCM = 0V, VOUT = 0V, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage VCM = V+ 220 1000 µV VCM = V– 220 1000 µV ∆VOS Input Offset Voltage Shift VCM = V– to V+ 150 1000 µV Input Offset Voltage Match (Channel-to-Channel) VCM = V–, V+ (Note 5) 200 1500 µV IB Input Bias Current VCM = V+ 0 550 1100 nA VCM = V– –1100 –550 0 nA ∆IB Input Bias Current Shift VCM = V– to V+ 1100 2200 nA Input Bias Current Match (Channel-to-Channel) VCM = V+ (Note 5) 20 300 nA VCM = V– (Note 5) 20 300 nA IOS Input Offset Current VCM = V+ 20 150 nA VCM = V– 20 150 nA ∆IOS Input Offset Current Shift VCM = V– to V+ 40 300 nA Input Noise Voltage 0.1Hz to 10Hz 300 nVP-P en Input Noise Voltage Density f = 1kHz 6 nV/√Hz in Input Noise Current Density f = 1kHz 0.9 pA/√Hz CIN Input Capacitance f = 100kHz 3 pF AVOL Large-Signal Voltage Gain VO = –14.5V to 14.5V, RL = 10k 1000 5000 V/mV VO = –10V to 10V, RL = 2k 650 3500 V/mV Channel Separation VO = –10V to 10V, RL = 2k 112 134 dB CMRR Common Mode Rejection Ratio VCM = V– to V+ 89 106 dB CMRR Match (Channel-to-Channel) (Note 5) VCM = V– to V+ 86 110 dB PSRR Power Supply Rejection Ratio VS = ±5V to ±15V 87 105 dB PSRR Match (Channel-to-Channel) (Note 5) VS = ±5V to ±15V 82 107 dB VOL Output Voltage Swing Low (Note 6) No Load 16 35 mV ISINK = 5mA 150 300 mV ISINK = 25mA 600 1200 mV VOH Output Voltage Swing High (Note 6) No Load 15 40 mV ISINK = 5mA 250 500 mV ISINK = 25mA 1200 2400 mV ISC Short-Circuit Current ±35 ±70 mA IS Supply Current per Amplifier 4.1 5.0 mA GBW Gain-Bandwidth Product (Note 7) f = 100kHz 15 30 MHz SR Slew Rate AV = –1, RL = Open, VO = ±10V, 5 10 V/µs Measure at VO = ±5V tS Settling Time 0.01%, VSTEP = 10V, AV = 1, RL = 1k 1.2 µs 16301fa Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Applications Information Package Description Typical Application Related Parts
