Datasheet LT1224 (Analog Devices) - 2
DescriptionVery High Speed Operational Amplifier
Pages / Page8 / 2 — ABSOLUTE. AXI U. R TI GS. PACKAGE/ORDER I FOR ATIO. ELECTRICAL CHAR C. A …
File Format / SizePDF / 217 Kb
ABSOLUTE. AXI U. R TI GS. PACKAGE/ORDER I FOR ATIO. ELECTRICAL CHAR C. A TERISTICS VS =. 15V, TA = 25
ABSOLUTE AXI U R TI GS PACKAGE/ORDER I FOR ATIO ELECTRICAL CHAR C A TERISTICS VS = 15V, TA = 25
LT1224
W W W U U W U ABSOLUTE AXI U A R TI GS PACKAGE/ORDER I FOR ATIO
Total Supply Voltage (V+ to V–) ... 36V TOP VIEW ORDER PART Differential Input Voltage ... ±6V NULL 1 8 NULL NUMBER Input Voltage ..±VS –IN 2 7 + V Output Short Circuit Duration (Note 1) .. Indefinite LT1224CN8 +IN 3 6 OUT Operating Temperature Range – LT1224CS8 V 4 5 NC LT1224C .. 0°C to 70°C Maximum Junction Temperature N8 PACKAGE S8 PACKAGE 8-LEAD PLASTIC DIP 8-LEAD PLASTIC SOIC S8 PART MARKING Plastic Package .. 150°C LT1224 • POI01 Storage Temperature Range ... – 65°C to 150°C TJMAX = 150°C, θJA = 100°C/W (N8) 1224 TJMAX = 150°C, θJA = 150°C/W (S8) Lead Temperature (Soldering, 10 sec.)... 300°C
15V, TA = 25
C, RL = 1k, VCM = 0V unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage (Note 2) 0.5 2.0 mV IOS Input Offset Current 100 400 nA IB Input Bias Current 4 8 µA en Input Noise Voltage f = 10kHz 22 nV/√Hz in Input Noise Current f = 10kHz 1.5 pA/√Hz RIN Input Resistance VCM = ±12V 24 40 MΩ Differential 250 kΩ CIN Input Capacitance 2 pF Input Voltage Range + 12 14 V Input Voltage Range – – 13 – 12 V CMRR Common-Mode Rejection Ratio VCM = ±12V 86 100 dB PSRR Power Supply Rejection Ratio VS = ±5V to ±15V 75 84 dB AVOL Large-Signal Voltage Gain VOUT = ±10V, RL = 500Ω 3.3 7 V/mV VOUT Output Swing RL = 500Ω ±12.0 ±13.3 V IOUT Output Current VOUT = ±12V 24 40 mA SR Slew Rate AVCL = –2, (Note 3) 250 400 V/µs Full Power Bandwidth 10V Peak, (Note 4) 6.4 MHz GBW Gain-Bandwidth f = 1MHz 45 MHz tr, tf Rise Time, Fall Time AVCL = 1, 10% to 90%, 0.1V 5 ns Overshoot AVCL = 1, 0.1V 30 % Propagation Delay 50% VIN to 50% VOUT 5 ns ts Settling Time 10V Step, 0.1% 90 ns Differential Gain f = 3.58MHz, RL = 150Ω 1 % Differential Phase f = 3.58MHz, RL = 150Ω 2.4 Deg RO Output Resistance AVCL = 1, f = 1MHz 2.5 Ω IS Supply Current 7 9 mA 2
