Datasheet LT6555 (Analog Devices) - 4
Description650MHz Gain of 2 Triple 2:1Video Multiplexer
Pages / Page16 / 4 — TYPICAL PERFOR A CE CHARACTERISTICS. Supply Current per Amplifier. vs …
File Format / SizePDF / 374 Kb
TYPICAL PERFOR A CE CHARACTERISTICS. Supply Current per Amplifier. vs Temperature. vs Supply Voltage. vs EN Pin Voltage
TYPICAL PERFOR A CE CHARACTERISTICS Supply Current per Amplifier vs Temperature vs Supply Voltage vs EN Pin Voltage
LT6555
W U TYPICAL PERFOR A CE CHARACTERISTICS Supply Current per Amplifier Supply Current per Amplifier Supply Current per Amplifier vs Temperature vs Supply Voltage vs EN Pin Voltage
12 12 12 VS = ±5V VEN, VIN, VDGND, VSEL = 0V VS = ±5V RL = ∞ TA = 25°C RL = ∞ 10 VIN = 0V 10 10 V V IN = 0V EN = 0V V T EN = 0.4V A = –55°C 8 8 8 TA = 25°C 6 6 6 TA = 125°C 4 4 4 SUPPLY CURRENT (mA) SUPPLY CURRENT (mA) SUPPLY CURRENT (mA) 2 2 2 VEN = 4V 0 0 0 –55 –35 –15 5 25 45 65 85 105 125 0 1 2 3 4 5 6 7 8 9 10 11 12 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 TEMPERATURE (°C) TOTAL SUPPLY VOLTAGE (V) EN PIN VOLTAGE (V) 6555 G01 6555 G02 6555 G03
Input Referred Offset Voltage Input Bias Current vs Temperature vs Temperature EN Pin Current vs EN Pin Voltage
15 0 0 VS = ±5V VS = ±5V VS = ±5V VIN = 0V –5 VDGND = 0V 10 –20 µA) –10 VIN = 0V –40 5 VIN = 1.5V µA) –15 –60 TA = 125°C 0 –20 TA = –55°C VIN = –1.5V –80 –25 –5 TA = 25°C OFFSET VOLTAGE (mV) EN PIN CURRENT ( –100 INPUT BIAS CURRENT ( –30 –10 –35 –120 –15 –40 –140 –55 –35 –15 5 25 45 65 85 105 125 –55 –35 –15 5 25 45 65 85 105 125 0 1 2 3 4 5 TEMPERATURE (°C) TEMPERATURE (°C) EN PIN VOLTAGE (V) 6555 G04 6555 G05 6555 G06
Maximum Output Voltage Swing Output Voltage Swing Output Voltage Swing vs VREF Pin Voltage vs ILOAD (Output High) vs ILOAD (Output Low)
4 5 0 TA = –55°C VS = ±5V VS = ±5V 3 V V HIGH SWING IN = 2V V IN = –2V REF INPUT TA = 125°C V V 4 VREF = 0V CLAMPING –1 VREF = 0V TA = 25°C 2 TA = 25°C T T A = 125°C A = –55°C 1 3 –2 0 T V A = 125°C S = ±5V –1 2 –3 RL = 150Ω TA = 25°C TA = 125°C OUTPUT VOLTAGE (V) OUTPUT VOLTAGE (V) OUTPUT VOLTAGE (V) –2 TA = 25°C 1 –4 V T REF INPUT –3 LOW SWING A = –55°C CLAMPING TA = –55°C –4 0 –5 –2 –1.5 –1 –0.5 0 0.5 1 1.5 2 0 10 20 30 40 50 60 70 80 90 100 0 10 20 30 40 50 60 70 80 90 100 VREF PIN VOLTAGE (V) SOURCE CURRENT (mA) SINK CURRENT (mA) 6555 G07 6555 G08 6555 G09 6555f 4
