Datasheet LT6557 (Analog Devices) - 7
Description500MHz, 2200V/µs Gain of 2, Single Supply Triple Video Amplifier with Input Bias Control
Pages / Page12 / 7 — TYPICAL PERFORMANCE CHARACTERISTICS. Overdriven Output Recovery. …
File Format / SizePDF / 615 Kb
TYPICAL PERFORMANCE CHARACTERISTICS. Overdriven Output Recovery. Enable/Disable Response. Large-Signal Transient Response
TYPICAL PERFORMANCE CHARACTERISTICS Overdriven Output Recovery Enable/Disable Response Large-Signal Transient Response
LT6557
5 6 VIN VEN(DISABLE) V 5 OUT 4 4 VS = 5V = 1V/DIV VOUT = 2VP-P 3 AC COUPLED OUT 3 RL = 150W 2 2 VOLTAGE (V) VOUT = 0.5V/DIV, V 1 INV 1 VS = 5V V 0 IN = 2.4VP-P RL = 1509 VEN(ENABLE) 0 –1 0 25 50 75 100 125 150 175 200 225 250 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 2.0 2.2 TIME (ns) TIME (ms) 6557 G28 6557 G29
Large-Signal Transient Response Small-Signal Transient Response
2.65 VS = 5V VIN = 50mVP-P RL = 1509 2.60 2.55 OUTPUT (V) 2.50 2.45 0 2 4 6 8 10 12 14 16 18 20 22 24 TIME (ns) 6557 G31
PIN FUNCTIONS EN (Pin 1):
Enable Control Pin. The part is enabled when
IN G (Pin 5):
Green Channel Input. This pin has a nomi- this pin is pulled low. An internal pull-up resistor of 40k nal impedance of 200kΩ with input bias circuit inactive, will turn the part off if this pin is unconnected. Pin 16 open.
GND (Pin 2):
Ground Reference for Enable Pin (Pin 1)
GND G (Pin 6):
Ground of Green Channel Amplifi er. This and Bias Control Voltage Pin (Pin 16). This pin must be pin is not internally connected to other ground pins and connected externally to ground. must be connected externally to ground.
IN R (Pin 3):
Red Channel Input. This pin has a nominal
IN B (Pin 7):
Blue Channel Input. This pin has a nominal impedance of 200kΩ with input bias circuit inactive, impedance of 200kΩ with input bias circuit inactive, Pin 16 open. Pin 16 open.
GND R (Pin 4):
Ground of Red Channel Amplifi er. This pin
GND B (Pin 8):
Ground of Blue Channel Amplifi er. This is not internally connected to other ground pins and must pin is not internally connected to other ground pins and be connected externally to ground. must be connected externally to ground. 6557fa 7
