Datasheet LT1970 (Analog Devices) - 2
Description500mA Power Op Amp with Adjustable Precision Current Limit
Pages / Page26 / 2 — absoluTe MaxiMuM raTings. pin conFiguraTion. (Note 1). orDer inForMaTion …
File Format / SizePDF / 402 Kb
absoluTe MaxiMuM raTings. pin conFiguraTion. (Note 1). orDer inForMaTion LEAD FREE FINISH. TAPE AND REEL. PART MARKING*
absoluTe MaxiMuM raTings pin conFiguraTion (Note 1) orDer inForMaTion LEAD FREE FINISH TAPE AND REEL PART MARKING*
LT1970
Supply Voltage (V TOP VIEW CC to VEE) ... 36V Positive High Current Supply (V+) ... V– to VCC VEE 1 20 VEE Negative High Current Supply(V–) ..V V– 2 19 V+ EE to V+ 21 Amplifier Output (OUT) ... V– to V+ OUT 3 18 TSD Current Sense Pins SENSE+ 4 17 ISNK (SENSE+, SENSE–, FILTER) ... V– to V+ FILTER 5 16 ISRC – + Logic Outputs (ISRC, ISNK, TSD) ... COMMON to V SENSE– 6 15 ENABLE CC VCC 7 14 COMMON Input Voltage (–IN, +IN) .. VEE – 0.3V to VEE + 36V –IN 8 13 VC Input Current ... 10mA SRC +IN 9 12 VCSNK Current Control Inputs VEE 10 11 VEE (VCSRC, VCSNK) ..COMMON to COMMON + 7V Enable Logic Input .. COMMON to V FE PACKAGE CC 20-LEAD PLASTIC TSSOP COMMON ... VEE to VCC TJMAX = 150°C, θJA = 40°C/W (NOTE 8) EXPOSED PAD (PIN 21) IS CONNECTED TO V Output Short-Circuit Duration ... Indefinite EE Operating Temperature Range (Note 2)..–40°C to 85°C Specified Temperature Range (Note 3) .. –40°C to 85°C Maximum Junction Temperature.. 150°C Storage Temperature Range ...–65°C to 150°C Lead Temperature (Soldering, 10 sec) .. 300°C
orDer inForMaTion LEAD FREE FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION SPECIFIED TEMPERATURE RANGE
LT1970CFE#PBF LT1970CFE#TRPBF LT1970CFE 20-Lead Plastic TSSOP 0°C to 70°C LT1970IFE#PBF LT1970IFE#TRPBF LT1970IFE 20-Lead Plastic TSSOP –40°C to 85°C Consult LTC Marketing for parts specified with wider operating temperature ranges. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/. Some packages are available in 500 unit reels through designated sales channels with #TRMPBF suffix.
elecTrical characTerisTics The
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. See Test Circuit for standard test conditions. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Power Op Amp Characteristics
VOS Input Offset Voltage 200 600 µV 0°C < TA < 70°C l 1000 µV –40°C < TA < 85°C l 1300 µV Input Offset Voltage Drift (Note 4) l –10 –4 10 µV/°C IOS Input Offset Current VCM = 0V l –100 100 nA IB Input Bias Current VCM = 0V l –600 –160 nA Input Noise Voltage 0.1Hz to 10Hz 3 µVP-P en Input Noise Voltage Density 1kHz 15 nV/√Hz in Input Noise Current Density 1kHz 3 pA/√Hz 1970fe 2 For more information www.linear.com/LT1970 Document Outline Description Typical Application Absolute Maximum Ratings Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Applications Information Package Description Related Parts
