Datasheet LT6300 (Analog Devices) - 2
Description500mA, 200MHz xDSL Line Driver in 16-Lead SSOP Package
Pages / Page16 / 2 — ABSOLUTE MAXIMUM RATINGS. PACKAGE/ORDER INFORMATION. (Note 1). ELECTRICAL …
File Format / SizePDF / 240 Kb
ABSOLUTE MAXIMUM RATINGS. PACKAGE/ORDER INFORMATION. (Note 1). ELECTRICAL CHARACTERISTICS. The
ABSOLUTE MAXIMUM RATINGS PACKAGE/ORDER INFORMATION (Note 1) ELECTRICAL CHARACTERISTICS The
LT6300
W W W U U W U ABSOLUTE MAXIMUM RATINGS PACKAGE/ORDER INFORMATION (Note 1)
Supply Voltage (V + to V –) ... ±13.5V TOP VIEW ORDER PART Input Current ... ±10mA V– 1 16 V– NUMBER Output Short-Circuit Duration (Note 2) ... Indefinite –IN 2 15 OUT LT6300CGN Operating Temperature Range ... – 40°C to 85°C +IN 3 14 NC LT6300IGN Specified Temperature Range (Note 3) .. – 40°C to 85°C SHDN 4 13 V+ Junction Temperature .. 150°C SHDNREF 5 12 V+ Storage Temperature Range ... – 65°C to 150°C +IN 6 11 NC GN PART Lead Temperature (Soldering, 10 sec).. 300°C –IN 7 10 OUT MARKING V– 8 9 V– 6300 GN PACKAGE 16-LEAD PLASTIC SSOP 6300I TJMAX = 150°C, θJA = 70°C/W to 95°C/W (Note 4) Consult LTC Marketing for parts specified with wider operating temperature ranges.
denotes the specifications which apply over the full specified temperature range, otherwise specifications are at TA = 25
C. VCM = 0V, pulse tested,
5V
VS
12V, VSHDNREF = 0V, RBIAS = 24.9k between V+ and SHDN unless otherwise noted. (Note 3) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage 1 5.0 mV ● 7.5 mV Input Offset Voltage Matching 0.3 5.0 mV ● 7.5 mV Input Offset Voltage Drift ● 10 µV/°C IOS Input Offset Current 100 500 nA ● 800 nA IB Input Bias Current ±0.1 ±4 µA ● ±6 µA Input Bias Current Matching 100 500 nA ● 800 nA en Input Noise Voltage Density f = 10kHz 8 nV/√Hz in Input Noise Current Density f = 10kHz 0.8 pA/√Hz RIN Input Resistance VCM = (V+ – 2V) to (V–+ 2V) ● 5 50 MΩ Differential 6.5 MΩ CIN Input Capacitance 3 pF Input Voltage Range (Positive) (Note 5) ● V+ – 2 V+ – 1 V Input Voltage Range (Negative) (Note 5) ● V– + 1 V– + 2 V CMRR Common Mode Rejection Ratio VCM = (V+ – 2V) to (V– + 2V) 74 83 dB ● 66 dB PSRR Power Supply Rejection Ratio VS = ±4V to ±12V 74 88 dB ● 66 dB 2
