Datasheet LT1010 (Analog Devices)
DescriptionFast ±150mA Power Buffer
Pages / Page20 / 1 — FTEATURES. DESCRIPTION. APPLICATIONS. TYPICAL APPLICATION. Very Low …
File Format / SizePDF / 704 Kb
FTEATURES. DESCRIPTION. APPLICATIONS. TYPICAL APPLICATION. Very Low Distortion Buffered Preamplifier
Datasheet LT1010 Analog Devices
LT1010 Fast ±150mA Power Buffer
FTEATURES DESCRIPTION
n 20MHz Bandwidth The LT®1010 is a fast, unity-gain buffer that can increase n 75V/µs Slew Rate the output capability of existing IC op amps by more than n Drives ±10V Into 75Ω an order of magnitude. This easy-to-use part makes fast n 5mA Quiescent Current amplifiers less sensitive to capacitive loading and reduces n Drives Capacitive Loads > 1µF thermal feedback in precision DC amplifiers. n Current and Thermal Limit Designed to be incorporated within the feedback loop, the n Operates from Single Supply ≥ 4.5V buffer can isolate almost any reactive load. Speed can be n Very Low Distortion Operation improved with a single external resistor. Internal operating n Available in 8-Pin miniDIP, Plastic TO-220 currents are essentially unaffected by the supply voltage and Tiny 3mm × 3mm × 0.75mm 8-Pin DFN Packages range. Single supply operation is also practical.
This monolithic IC is supplied in 8-pin miniDIP, plastic TO-220 and 8-pin DFN packages. The low thermal re- sistance power package is an aid in reducing operating n Boost Op Amp Output junction temperatures. n Isolate Capacitive Loads n Drive Long Cables L, LT, LTC and LTM are registered trademarks of Linear Technology Corporation. All other trademarks are the property of their respective owners. n Audio Amplifiers n Video Amplifiers n Power Small Motors n Operational Power Supply n FET Driver
TYPICAL APPLICATION Very Low Distortion Buffered Preamplifier
V+ 18V C2 0.4 R7 V 22pF OUT = 10VP-P 50Ω RL = 400Ω R1 V+ 1k 0.3 3 + 7 R6 BOOST R8 100Ω 6 IN OUT 100Ω LT1056CN8 LT1010CT OUTPUT R2 C1 2 0.2 1M 22pF – R3 4 R4 V– 1k 10k V+ 0.1 HARMONIC DISTORTION (%) LM334 NOTE 1: ALL RESISTORS 1% METAL FILM RSET NOTE 2: SUPPLIES WELL BYPASSED AND LOW ZO 33.2Ω ISET = 2mA V– 0 1% 10 100 1k 10k 100k V+ FREQUENCY (Hz) 1010 TA01 –18V 1010 TA02 1010fe 1 Document Outline Fteatures Applications Description Typical Application Absolute Maximum Ratings Preconditioning Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Applications Information Schematic Diagram Definition Of Terms Package Description Revision History Related Parts
