Datasheet RH6200M (Analog Devices) - 6
DescriptionLow Noise, High Speed Rail-to-Rail Op Amp
Pages / Page10 / 6 — TYPICAL PERFORMANCE CHARACTERISTICS. Settling Time vs Output Step. …
File Format / SizePDF / 158 Kb
TYPICAL PERFORMANCE CHARACTERISTICS. Settling Time vs Output Step. Open-Loop Gain vs Frequency. Slew Rate vs Temperature
TYPICAL PERFORMANCE CHARACTERISTICS Settling Time vs Output Step Open-Loop Gain vs Frequency Slew Rate vs Temperature
RH6200M
TYPICAL PERFORMANCE CHARACTERISTICS Settling Time vs Output Step Open-Loop Gain vs Frequency Slew Rate vs Temperature (Noninverting)
80 120 140 200 A VS = ±5V 70 PHASE 100 V = –1 R A – 120 F = RG = 1k V = 1 60 80 RL = 1k TA = 25°C V VOUT CM = 0.5V 150 + 500Ω 50 60 100 VS = ±5V RISING VIN PHASE (DEG) GAIN 40 V V CM = 4.5V 40 S = ±5V FALLING 80 30 20 100 GAIN (dB) 1mV 1mV 20 0 60 V V CM = 4.5V CM = 0.5V 10 –20 SLEW RATE (V/μs) 40 V SETTLING TIME (ns) S = ±2.5V RISING 50 0 –40 V V S = ±2.5V FALLING S = 5V, 0V 10mV 10mV 20 –10 CL = 5pF –60 RL = 1k –20 –80 0 0 100k 1M 10M 100M 1G –55 –35 –15 5 25 45 65 85 105 125 –4 –3 –2 –1 0 1 2 3 4 FREQUENCY (Hz) OUTPUT STEP (V) RH6200 G12 TEMPERATURE (°C) RH6200 G13 RH6200 G14
Settling Time vs Output Step (Inverting) Distortion vs Frequency, AV = 1 5V Large-Signal Response
200 –50 VS = ±5V 500Ω AV = 1 AV = –1 VO = 2VP-P T 500Ω – 5V A = 25°C V –60 V IN S = ±5V 150 VOUT + –70 HD2, R 1V/DIV L = 1k 100 –80 1mV 1mV HD2, RL = 100Ω –90 0V SETTLING TIME (ns) DISTORTION (dBc) 50 HD3, RL = 1k 10mV 10mV –100 RH6200 G17 HD3, R V 200ns/DIV S = 5V, 0V L = 100Ω AV = 1 0 –110 RL = 1k –4 –3 –2 –1 0 1 2 3 4 100k 1M 10M OUTPUT STEP (V) FREQUENCY (Hz) RH6200 G15 RH6200 G16 rh6200mfa 6
