Datasheet RH6200M (Analog Devices) - 8
Description | Low Noise, High Speed Rail-to-Rail Op Amp |
Pages / Page | 10 / 8 — TYPICAL PERFORMANCE CHARACTERISTICS. Open-Loop Voltage Gain,. Input Bias … |
File Format / Size | PDF / 158 Kb |
TYPICAL PERFORMANCE CHARACTERISTICS. Open-Loop Voltage Gain,. Input Bias Current. RL = 1k. RL = 100Ω. Common Mode Rejection Ratio
RH6200M
TYPICAL PERFORMANCE CHARACTERISTICS Open-Loop Voltage Gain, Open-Loop Voltage Gain, Input Bias Current RL = 1k RL = 100Ω
30 200 30 VS = ±5V 175 20 V 25 S = ±5V V VCM = 5V 150 S = ±5V 10 20 125 0 100 V V S = 5V, 0V 15 S = 5V, 0V 75 –10 10 OPEN LOOP GAIN (V/mV) 50 OPEN LOOP GAIN (V/mV) INPUT BIAS CURRENT (μA) –20 VCM = –5V 5 25 –30 0 0 1 10 100 1000 1 10 100 1000 1 10 100 1000 TOTAL DOSE KRAD (Si) TOTAL DOSE KRAD (Si) TOTAL DOSE KRAD (Si) RH6200 G24 RH6200 G25 RH6200 G26
Common Mode Rejection Ratio Common Mode Rejection Ratio Power Supply Rejection Ratio
120 120 80 VS = 5V, 0V VS = ±5V VS = ±2.25V TO ±5V 75 110 110 VCM = –2V to 2V VCM = 1.5V to 3.5V 70 100 100 65 CMRR (dB) 90 CMRR (dB) 90 60 VCM = –5V to 5V 80 80 V 55 CM = 0V to 5V POWER SUPPLY REJECTION RATIO (dB) 70 70 50 1 10 100 1000 1 10 100 1000 1 10 100 1000 TOTAL DOSE KRAD (Si) TOTAL DOSE KRAD (Si) TOTAL DOSE KRAD (Si) RH6200 G27 RH6200 G28 RH6200 G29 rh6200mfa 8
