Datasheet LT6205, LT6206, LT6207 (Analog Devices) - 8
DescriptionQuad Single Supply 3V, 100MHz Video Op Amps
Pages / Page18 / 8 — TYPICAL PERFORMANCE CHARACTERISTICS. Short-Circuit Current vs …
File Format / SizePDF / 267 Kb
TYPICAL PERFORMANCE CHARACTERISTICS. Short-Circuit Current vs Temperature. Open-Loop Gain. Input Noise Voltage Density
TYPICAL PERFORMANCE CHARACTERISTICS Short-Circuit Current vs Temperature Open-Loop Gain Input Noise Voltage Density
LT6205/LT6206/LT6207
TYPICAL PERFORMANCE CHARACTERISTICS Short-Circuit Current vs Temperature Open-Loop Gain Open-Loop Gain
90 500 500 V V S = p5V VS = 5V, 0V S = p5V 400 V 400 CM = 1V TA = 25°C 80 T 300 A = 25°C 300 SINKING V) 200 V) 200 70 100 100 TAGE (μ RL = 1k RL = 1k 60 SOURCING 0 TAGE ( μ 0 T-CIRCUIT CURRENT (mA) –100 –100 50 RL = 150Ω RL = 150Ω INPUT VOL –200 INPUT VOL –200 –300 –300 40 –400 –400 OUTPUT SHOR 3O –500 –500 –50 –25 0 25 50 75 100 125 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 –5 –4 –3 –2 –1 0 1 2 3 4 5 TEMPERATURE (°C) OUTPUT VOLTAGE (V) OUTPUT VOLTAGE (V) 620567 G10 620567 G11 620567 G12
Input Noise Voltage Density Input Noise Current Density Warm Up Drift vs Time (LT6206) vs Frequency vs Frequency
120 30 16 TA = 25°C VS = 5V, 0V VS = 5V, 0V Hz) V Hz) CM = 1V • 14 VCM = 1V V) 100 /• 25 T T V A = 25°C A = 25°C S = ±5V Y (nV Y (pA/ 12 TAGE (μ 80 20 10 VS = 5V, 0V 60 15 8 TAGE DENSIT 6 40 10 4 CHANGE IN OFFSET VOL 20 5 2 INPUT NOISE VOL INPUT NOISE CURRENT DENSIT 0 0 0 0 10 20 30 40 50 60 70 80 90 100 100 1k 10k 100k 100 1k 10k 100k TIME AFTER POWER-UP (s) FREQUENCY (Hz) FREQUENCY (Hz) 620567 G14 620567 G15 620567 G13
Gain Bandwidth and Phase 0.1Hz to 10Hz Noise Voltage Gain and Phase vs Frequency Margin vs Supply Voltage
70 140 50 VS = 5V, 0V TA = 25°C V PHASE CM = 1V 60 120 RF = RG = 1k TA = 25°C CL = 5pF 45 50 100 V PHASE MARGIN (DEG) S = 3V, 0V PHASE MARGIN /DIV) V 40 80 PHASE (DEG) 40 μ VS = p5V 30 60 110 35 TAGE (1 20 40 GAIN (dB) GAIN BANDWIDTH 10 20 105 NOISE VOL GAIN BANDWIDTH (MHz) 0 VS = 3V, 0V 0 TA = 25°C 100 –10 R GAIN V -20 L = 1k S = p5V CL = 5pF –20 -40 95 100k 1M 10M 100M 500M 0 2 4 6 8 10 12 TIME (2 SEC/DIV) FREQUENCY (Hz) TOTAL SUPPLY VOLTAGE (V) 620567 G16 620567 G17 620567 G18 620567fc 8 Document Outline FEATURES DESCRIPTION APPLICATIONS TYPICAL APPLICATION ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION ORDER INFORMATION ELECTRICAL CHARACTERISTICS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION TYPICAL APPLICATION PACKAGE DESCRIPTION REVISION HISTORY TYPICAL APPLICATION RELATED PARTS
