Datasheet LT6552 (Analog Devices) - 2
Description3.3V Single Supply Video Difference Amplifier
Pages / Page16 / 2 — ABSOLUTE AXI U. RATI GS (Note 1). PACKAGE/ORDER I FOR ATIO. 3.3V …
File Format / SizePDF / 364 Kb
ABSOLUTE AXI U. RATI GS (Note 1). PACKAGE/ORDER I FOR ATIO. 3.3V ELECTRICAL CHARACTERISTICS The
ABSOLUTE AXI U RATI GS (Note 1) PACKAGE/ORDER I FOR ATIO 3.3V ELECTRICAL CHARACTERISTICS The
LT6552
W W W U ABSOLUTE AXI U RATI GS (Note 1)
Supply Voltage (V+ to V–) .. 12.6V Specified Temperature Range (Note 5) ..–40°C to 85°C Input Current (Note 2) .. ±10mA Maximum Junction Temperature .. 150°C Input Voltage Range ... V– to V+ (DD Package) ... 125°C Differential Input Voltage Storage Temperature Range ..–65°C to 150°C +Input (Pin 3) to –Input (Pin 2) .. ±VS (DD Package) ..–65°C to 125°C Output Short-Circuit Duration (Note 3) .. Indefinite Lead Temperature Operating Temperature Range (Note 4) ...–40°C to 85°C (Soldering, 10 sec) ... 300°C
U W U PACKAGE/ORDER I FOR ATIO
ORDER PART ORDER PART TOP VIEW NUMBER TOP VIEW NUMBER REF 1 8 FB REF 1 8 FB LT6552CDD LT6552CS8 –IN 2 7 V+ –IN 2 7 V+ LT6552IDD +IN 3 6 OUT LT6552IS8 +IN 3 6 OUT V– 4 5 SHDN V– 4 5 SHDN DD PART MARKING* S8 PART MARKING DD PACKAGE S8 PACKAGE 8-LEAD (3mm × 3mm) PLASTIC DFN 8-LEAD PLASTIC SO T T JMAX = 150°C, θJA = 100°C/W JMAX = 125°C, θJA = 160°C/W LADR 6552 UNDERSIDE METAL CONNECTED TO V– 6552I (PCB CONNECTION OPTIONAL) *The temperature grade is identified by a label on the shipping container. Consult LTC Marketing for parts specified with wider operating temperature ranges.
C. VS = 3.3V, 0V. Figure 1 shows the DC test circuit, VREF = VCM = 1V, VDIFF = 0V, VSHDN = V+, unless otherwise noted. RL = RF + RG = 1k. (Note 6) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage Both Inputs (Note 7) 5 20 mV ● 25 mV ∆VOS/∆T Input VOS Drift ● 40 µV/°C IB Input Bias Current Any Input ● 20 50 µA IOS Input Offset Current Either Input Pair ● 1 5 µA 6552f 2
