Datasheet LT6220, LT6221, LT6222 (Analog Devices) - 6
DescriptionSingle/Dual/Quad 60MHz, 20V/µs, Low Power, Rail-to-Rail Input and Output Precision Op Amps
Pages / Page22 / 6 — e lecTrical characTerisTics. TA = 25°C, VS = ±5V, VCM = 0V, VOUT = 0V, …
File Format / SizePDF / 373 Kb
e lecTrical characTerisTics. TA = 25°C, VS = ±5V, VCM = 0V, VOUT = 0V, unless otherwise noted. SYMBOL. PARAMETER. CONDITIONS
e lecTrical characTerisTics TA = 25°C, VS = ±5V, VCM = 0V, VOUT = 0V, unless otherwise noted SYMBOL PARAMETER CONDITIONS
LT6220/LT6221/LT6222
e lecTrical characTerisTics TA = 25°C, VS = ±5V, VCM = 0V, VOUT = 0V, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage VCM = –5V 80 500 µV VCM = –5V (DD Package) 150 750 µV VCM = –5V (S5 Package) 200 900 µV VCM = 5V 0.7 2.5 mV VCM = 5V (S5 Package) 0.7 3 mV ∆VOS Input Offset Voltage Shift VCM = –5V to 3.5V 70 675 µV Input Offset Voltage Match (Channel-to-Channel) VCM = –5V 100 850 µV (Note 9) VCM = –5V (DD Package) 150 1300 µV IB Input Bias Current VCM = –4V 20 150 nA VCM = 5V 250 700 nA Input Bias Current Match (Channel-to-Channel) VCM = –4V 15 175 nA VCM = 5V 20 250 nA IOS Input Offset Current VCM = –4V 15 100 nA VCM = 5V 15 100 nA Input Noise Voltage 0.1Hz to 10Hz 0.5 µVP-P en Input Noise Voltage Density f = 10kHz 10 nV/√Hz in Input Noise Current Density f = 10kHz 0.8 pA/√Hz CIN Input Capacitance f = 100kHz 2 pF AVOL Large Signal Voltage Gain VOUT = –4V to 4V, RL = 1k 35 95 V/mV VOUT = –2V to 2V, RL = 100Ω 3.5 10 V/mV CMRR Common Mode Rejection Ratio VCM = –5V to 3.5V 82 102 dB CMRR Match (Channel-to-Channel) 77 100 dB Input Common Mode Range V – + S VS V PSRR Power Supply Rejection Ratio V + – S = 2.5V to 10V, VS = 0V, VCM = 0V 84 105 dB PSRR Match (Channel-to-Channel) 79 105 dB VOL Output Voltage Swing LOW (Note 7) No Load 5 40 mV ISINK = 5mA 100 200 mV ISINK = 20mA 325 650 mV VOH Output Voltage Swing HIGH (Note 7) No Load 5 40 mV ISOURCE = 5mA 130 250 mV ISOURCE = 20mA 475 900 mV ISC Short-Circuit Current 25 50 mA IS Supply Current Per Amplifier 1 1.5 mA GBW Gain-Bandwidth Product Frequency = 1MHz 60 MHz SR Slew Rate AV = –1, RL = 1k, VOUT = ±4V, 20 V/µs Measure at VOUT = ±2V FPBW Full Power Bandwidth VOUT = 8VP-P 0.8 MHz HD Harmonic Distortion AV = 1, RL= 1k, VOUT = 2VP-P, fC = 500kHz –77.5 dBc tS Settling Time 0.01%, VSTEP = 5V, AV = 1, RL = 1k 375 ns ∆G Differential Gain (NTSC) AV = 2, RL = 1k 0.15 % ∆θ Differential Phase (NTSC) AV = 2, RL = 1k 0.6 Deg 622012fc 6 For more information www.linear.com/LT6220/LT6221/LT6222 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
