DatasheetLT6200, LT6200-5 LT6200-10, LT6201 (Analog Devices)
Description165MHz, Rail-to-Rail Input and Output, 0.95nV/√Hz Low Noise, Op Amp Family
Pages / Page26 / 1 — FeaTures. DescripTion. Low Noise Voltage: 0.95nV/√Hz (100kHz). Gain …
File Format / SizePDF / 548 Kb
FeaTures. DescripTion. Low Noise Voltage: 0.95nV/√Hz (100kHz). Gain Bandwidth Product:. LT6200/LT6201 165MHz AV = 1. LT6200-5
DatasheetLT6200, LT6200-5 LT6200-10, LT6201 Analog Devices
LT6200/LT6200-5 LT6200-10/LT6201 165MHz, Rail-to-Rail Input and Output, 0.95nV/√Hz Low Noise, Op Amp Family
FeaTures DescripTion
n
The LT®6200/LT6201 are single and dual ultralow noise, n
rail-to-rail input and output unity gain stable op amps
that feature 0.95nV/√Hz noise voltage. These amplifiers
LT6200-5 800MHz AV ≥ 5
combine very low noise with a 165MHz gain bandwidth,
LT6200-10 1.6GHz AV ≥ 10
50V/µs slew rate and are optimized for low voltage signal n
Low Distortion: –80dB at 1MHz, RL = 100Ω
conditioning systems. A shutdown pin reduces supply n
Dual LT6201 in Tiny DFN Package
current during standby conditions and thermal shutdown n
Input Common Mode Range Includes Both Rails
protects the part from overload conditions. n Output Swings Rail-to-Rail The LT6200-5/LT6200-10 are single amplifiers optimized n Low Offset Voltage: 1mV Max for higher gain applications resulting in higher gain n Wide Supply Range: 2.5V to 12.6V bandwidth and slew rate. The LT6200 family maintains n Output Current: 60mA Min its performance for supplies from 2.5V to 12.6V and are n Operating Temperature Range – 40°C to 85°C specified at 3V, 5V and ±5V. n Power Shutdown, Thermal Shutdown n SO-8 and Low Profile (1mm) ThinSOT™ Packages For compact layouts the LT6200/LT6200-5/LT6200-10 are available in the 6-lead ThinSOTTM and the 8-pin SO package. The dual LT6201 is available in an 8-pin SO package with
applicaTions
standard pinouts as well as a tiny, dual fine pitch leadless ■ Transimpedance Amplifiers package (DFN). These amplifiers can be used as plug-in ■ Low Noise Signal Processing replacements for many high speed op amps to improve ■ Active Filters input/output range and noise performance. ■ Rail-to-Rail Buffer Amplifiers L, LT, LTC, LTM, Linear Technology and the Linear logo are registered trademarks and ThinSOT is a trademark of Linear Technology Corporation. All other trademarks are the property ■ Driving A/D Converters of their respective owners.
Typical applicaTion Distortion vs Frequency Single Supply, 1.5nV/√Hz, Photodiode Amplifier
–50 AV = 1 5V C V F O = 2VP-P –60 VS = ±2.5V –70 IPD R PHILIPS F HD2, RL = 1k 10k BF862 –80 – HD2, RL = 100Ω HD3, RL = 1k PHOTO DISTORTION (dBc) –90 DIODE 1k VOUT ≈ 2V LT6200 + +IPD • RF –100 HD3, RL = 100Ω –110 10k 0.1µF 100k 1M 10M FREQUENCY (Hz) 6200 TA01 6200 G35 62001ff 1 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Applications Information Package Description Revision History Typical Application Related Parts
