Datasheet LT1800 (Analog Devices) - 4
Description80MHz, 25V/µs Low Power Rail-to-Rail Input and Output Precision Op Amp
Pages / Page18 / 4 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
File Format / SizePDF / 285 Kb
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the temperature range of
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the temperature range of
LT1800
denotes the specifi cations which apply over the temperature range of 0°C ≤ TA ≤ 70°C. C. VS = 5V, 0V; VS = 3V, 0V; VCM = VOUT = half supply, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
Input Common Mode Range l 0 VS V PSRR Power Supply Rejection Ratio VS = 2.5V to 10V, VCM = 0V l 74 91 dB Minimum Supply Voltage (Note 6) l 2.3 2.5 V VOL Output Voltage Swing Low (Note 7) No Load l 14 60 mV ISINK = 5mA l 100 200 mV ISINK = 20mA l 300 550 mV VOH Output Voltage Swing High (Note 7) No Load l 25 80 mV ISOURCE = 5mA l 150 300 mV ISOURCE = 20mA l 600 1000 mV ISC Short-Circuit Current VS = 5V l 20 40 mA VS = 3V l 20 30 mA IS Supply Current per Amplifi er l 2 2.75 mA GBW Gain Bandwidth Product Frequency = 2MHz l 35 75 MHz SR Slew Rate VS = 5V, AV = – 1, RL = 1k, VO = 4VP-P l 11 22 V/μs
The
denotes the specifi cations which apply over the temperature range of –40°C ≤ TA ≤ 85°C. VS = 5V, 0V; VS = 3V, 0V; VCM = VOUT = half supply, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage VCM = 0V l 175 700 μV VCM = 0V (SOT-23) l 400 2000 μV VCM = VS l 0.75 4 mV VCM = VS (SOT-23) l 0.9 4 mV ΔVOS Input Offset Shift VCM = 0V to VS – 1.5V l 30 300 μV VOS TC Input Offset Voltage Drift (Note 8) l 1.5 5 μV/°C IB Input Bias Current VCM = 1V l 50 400 nA VCM = VS – 0.2V l 600 2000 nA IOS Input Offset Current VCM = 1V l 25 300 nA VCM = VS – 0.2V l 25 300 nA AVOL Large-Signal Voltage Gain VS = 5V, VO = 0.5V to 4.5V, RL = 1k at VS/2 l 25 65 V/mV VS = 5V, VO = 1.5V to 3.5V, RL = 100Ω at VS/2 l 2.5 6 V/mV VS = 3V, VO = 0.5V to 2.5V, RL = 1k at VS/2 l 20 65 V/mV CMRR Common Mode Rejection Ratio VS = 5V, VCM = 0V to 3.5V l 81 101 dB VS = 3V, VCM = 0V to 1.5V l 73 93 dB Input Common Mode Range l 0 VS V PSRR Power Supply Rejection Ratio VS = 2.5V to 10V, VCM = 0V l 73 90 dB Minimum Supply Voltage (Note 6) l 2.3 2.5 V VOL Output Voltage Swing Low (Note 7) No Load l 15 70 mV ISINK = 5mA l 105 210 mV ISINK = 10mA l 170 400 mV VOH Output Voltage Swing High (Note 7) No Load l 25 90 mV ISOURCE = 5mA l 150 350 mV ISOURCE = 10mA l 300 700 mV ISC Short-Circuit Current VS = 5V l 12.5 30 mA VS = 3V l 12.5 30 mA IS Supply Current per Amplifi er l 2.1 3 mA GBW Gain Bandwidth Product Frequency = 2MHz l 30 70 MHz SR Slew Rate VS = 5V, AV = – 1, RL = 1k, VO = 4V l 10 18 V/μs 1800fa 4
