Datasheet LT1363 (Analog Devices) - 4
Description70MHz, 1000V/µs Op Amp
Pages / Page12 / 4 — ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply …
File Format / SizePDF / 220 Kb
ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply over the temperature range
ELECTRICAL CHARACTERISTICS The denotes the specifications which apply over the temperature range
LT1363
denotes the specifications which apply over the temperature range 0
C
TA
70
C, VCM = 0V unless otherwise noted. SYMBOL PARAMETER CONDITIONS VSUPPLY MIN TYP MAX UNITS
PSRR Power Supply Rejection Ratio VS = ±2.5V to ±15V ● 88 dB AVOL Large-Signal Voltage Gain VOUT = ±12V, RL = 1k ±15V ● 3.6 V/mV VOUT = ±10V, RL = 500Ω ±15V ● 2.4 V/mV VOUT = ±2.5V, RL = 500Ω ±5V ● 2.4 V/mV VOUT = ±2.5V, RL = 150Ω ±5V ● 1.5 V/mV VOUT = ±1V, RL = 500Ω ±2.5V ● 2.0 V/mV VOUT Output Swing RL = 1k, VIN = ±40mV ±15V ● 13.4 ±V RL = 500Ω, VIN = ±40mV ±15V ● 12.8 ±V RL = 500Ω, VIN = ±40mV ±5V ● 3.4 ±V RL = 150Ω, VIN = ±40mV ±5V ● 3.3 ±V RL = 500Ω, VIN = ±40mV ±2.5V ● 1.2 ±V IOUT Output Current VOUT = ±12.8V ±15V ● 25 mA VOUT = ±3.3V ±5V ● 22 mA ISC Short-Circuit Current VOUT = 0V, VIN = ±3V ±15V ● 55 mA SR Slew Rate AV = – 2, (Note 5) ±15V ● 600 V/µs ±5V ● 225 V/µs IS Supply Current ±15V ● 8.7 mA ±5V ● 8.4 mA
The
denotes the specifications which apply over the temperature range –40
C
TA
85
C, VCM = 0V unless otherwise noted. (Note 9) SYMBOL PARAMETER CONDITIONS VSUPPLY MIN TYP MAX UNITS
VOS Input Offset Voltage (Note 4) ±15V ● 2.5 mV ±5V ● 2.5 mV ±2.5V ● 2.7 mV Input VOS Drift (Note 7) ±2.5V to ±15V ● 10 13 µV/°C IOS Input Offset Current ±2.5V to ±15V ● 600 nA IB Input Bias Current ±2.5V to ±15V ● 3.6 µA CMRR Common Mode Rejection Ratio VCM = ±12V ±15V ● 82 dB VCM = ±2.5V ±5V ● 74 dB VCM = ±0.5V ±2.5V ● 64 dB PSRR Power Supply Rejection Ratio VS = ±2.5V to ±15V ● 87 dB AVOL Large-Signal Voltage Gain VOUT = ±12V, RL = 1k ±15V ● 2.5 V/mV VOUT = ±10V, RL = 500Ω ±15V ● 1.5 V/mV VOUT = ±2.5V, RL = 500Ω ±5V ● 1.5 V/mV VOUT = ±2.5V, RL = 150Ω ±5V ● 1.0 V/mV VOUT = ±1V, RL = 500Ω ±2.5V ● 1.3 V/mV VOUT Output Swing RL = 1kΩ, VIN = ±40mV ±15V ● 13.4 ±V RL = 500Ω, VIN = ±40mV ±15V ● 12.7 ±V RL = 500Ω, VIN = ±40mV ±5V ● 3.4 ±V RL = 150Ω, VIN = ±40mV ±5V ● 3.2 ±V RL = 500Ω, VIN = ±40mV ±2.5V ● 1.2 ±V IOUT Output Current VOUT = ±12.7V ±15V ● 25 mA VOUT = ±3.2V ±5V ● 21 mA ISC Short-Circuit Current VOUT = 0V, VIN = ±3V ±15V ● 50 mA SR Slew Rate AV = – 2, (Note 5) ±15V ● 550 V/µs ±5V ● 180 V/µs IS Supply Current ±15V ● 9.0 mA ±5V ● 8.7 mA 4
