Datasheet LT1363 (Analog Devices) - 5
Description70MHz, 1000V/µs Op Amp
Pages / Page12 / 5 — ELECTRICAL CHARACTERISTICS. Note 1:. Note 6:. Note 2:. Note 7:. Note 8:. …
File Format / SizePDF / 220 Kb
ELECTRICAL CHARACTERISTICS. Note 1:. Note 6:. Note 2:. Note 7:. Note 8:. Note 9:. Note 3:. Note 4:. Note 5:
ELECTRICAL CHARACTERISTICS Note 1: Note 6: Note 2: Note 7: Note 8: Note 9: Note 3: Note 4: Note 5:
LT1363
Note 6:
Full power bandwidth is calculated from the slew rate of a device may be impaired. measurement: FPBW = SR/2πVP.
Note 2:
Differential inputs of ±10V are appropriate for transient operation
Note 7:
This parameter is not 100% tested. only, such as during slewing. Large, sustained differential inputs will cause
Note 8:
The LT1363C is guaranteed functional over the operating excessive power dissipation and may damage the part. See Input temperature range of –40°C to 85°C. Considerations in the Applications Information section of this data sheet
Note 9:
The LT1363C is guaranteed to meet specified performance from for more details. 0°C to 70°C. The LT1363C is designed, characterized and expected to
Note 3:
A heat sink may be required to keep the junction temperature meet specified performance from – 40°C to 85°C, but is not tested or QA below absolute maximum when the output is shorted indefinitely. sampled at these temperatures. For guaranteed I-grade parts, consult the
Note 4:
Input offset voltage is pulse tested and is exclusive of warm-up drift. factory.
Note 5:
Slew rate is measured between ±10V on the output with ±6V input for ±15V supplies and ±2V on the output with ±1.75V input for ±5V supplies.
W U TYPICAL PERFORMANCE CHARACTERISTICS Supply Current vs Supply Voltage Input Common Mode Range vs Input Bias Current vs and Temperature Supply Voltage Input Common Mode Voltage
10 V + 1.0 T VS = ±15V – 0.5 A = 25°C ∆VOS < 1mV TA = 25°C + – 8 –1.0 I + I I B B 125°C ———— µA) 0.8 B = 2  –1.5 25°C 6 –2.0 0.6 – 55°C 4 2.0 1.5 SUPPLY CURRENT (mA) 0.4 2 COMMON MODE RANGE (V) INPUT BIAS CURRENT ( 1.0 0.5 0 V – 0.2 0 5 10 15 20 0 5 10 15 20 –15 –10 –5 0 5 10 15 SUPPLY VOLTAGE (±V) SUPPLY VOLTAGE (±V) INPUT COMMON MODE VOLTAGE (V) 1363 G01 1363 G02 1363 G03
Input Bias Current vs Open-Loop Gain vs Temperature Input Noise Spectral Density Resistive Load
1.4 100 10 85 VS = ±15V V T + – S = ±15V A = 25°C 1.2 I + I INPUT CURRENT NOISE (pA/ T I B B A = 25°C B =  ———— 2 AV = 101 80 √Hz) µA) R 1.0 S = 100k VS = ±15V VS = ±5V 75 0.8 e i n n 10 1 0.6 70 0.4 OPEN-LOOP GAIN (dB) √ INPUT BIAS CURRENT ( Hz) 65 0.2 INPUT VOLTAGE NOISE (nV/ 0 1 0.1 60 – 50 –25 0 25 50 75 100 125 10 100 1k 10k 100k 10 100 1k 10k TEMPERATURE (°C) FREQUENCY (Hz) LOAD RESISTANCE (Ω) 1363 G04 1363 G05 1363 G06 5
